Bulb running hot. Is it normal?
Old 10-09-2015, 02:55 AM
leonardothu's Avatar
2012 C250 Sport Sedan
Hey everyone, it's my first post on this forum so please bear with me. So I recently switched out my OEM halogen lights to the Philips Diamond Vision 55w H7 5000k bulbs. After awhile I touched the headlight assembly and it was burning! I was wondering if this was normal or is it something I should be worried about. I hope it won't affect my car in any way. Any advice would be greatly appreciated!
Old 10-09-2015, 09:38 AM
sagar526's Avatar
2010 C350
Running 55W bulbs will produce more heat and you run the slight possibility of burning your projector bowl. It can also melt the harness and mess up the electrical there. Look into getting 35W hids and you can get the same light output at a safer method.
Old 10-09-2015, 11:36 AM
Antique-Ace's Avatar
2014 CLS550-4M, 2013 C350-4M Coupe
A 55w H7 bulb is the correct bulb for the OP's headlights so why is he going melt his wiring harness and possibly burn his projector bowel using the correct 55w H7 bulb?
It's possible that the Philips Diamond Vision 55w H7 bulbs may run a little hotter than the stock Osram H7 bulbs, but I have not read anything about these Philips bulbs damaging projector housing or melting a wiring harness. I have been running Osram Rally 64217 H7 65 watt "off road use only" bulbs for my high beam and low beam headlights for nearly a year now in my '13 C350 with no deleterious effects whatsoever.
Old 10-09-2015, 11:42 AM
tpliquid's Avatar
C63, GT3RS, 430 Scud, E63, CGT
I believe he has halogens which is 55w. to 55w.
lights get hot. end of story
Old 10-09-2015, 12:17 PM
But shouldn't I use a recommended 55w voltage instead of a 35w?
Old 10-09-2015, 12:18 PM
Ahh that's a relief to hear. I feel much better now. Thank you!
Old 10-09-2015, 12:19 PM
Yes I have halogen bulbs. Good to know that's normal. Thank you!
Quick Reply: Bulb running hot. Is it normal?
