Dead Instrument Cluster...
2003 C230 Kompressor Coupe
Currently have 2013 C350, searched the forum as well as the web and couldnt find any real answers. I went to start my car after 5 days of not driving and the car started just fine, but the lcd screen along with the speedometer, tach, fuel and temp gauge do not work at all. Also when no indication of turn signals working either. ( Outside check does confirm that they still work) Any thoughts? Still under warranty and have a deal with the stealership wednesday but rather resolve it on my own. thank you for the help!
Yea, Ill probably end up doing that. They said they will check it out for 145 and hour if its not under warranty, seems like this should be covered? :/
I would then report that MB franchise to MB America Corporate for non-compliance of a manufacture warranty. Only if you want to see them burn though lol
EDIT: Here's the link for MBusa contact
http://mercedes-benz.custhelp.com/ap...SnlBSVB3QW0%3D
2014 Mercedes-Benz c300 4matic
May be a blown fuse, but fuses don't usually blow for no good reason. I agree with the others that the dealership should look at it. I can't think of a reason it wouldn't be covered.
83 500SEC, 87 300D, 02 C32(x2), 02 C320T (x2), 03 C320T4, 03 C320T, 03 E55, 05 E320CDI, 06 E320CDI
fwiw I had an 08 C300 in with a similar issue. only difference was occasionally the backlight would work but cluster lcd and all gauges were dead. power and ground to cluster were good, and no communication with it was possible. replacing the cluster resolved the issue.
Mercedes Benz C200K (w204 - m271)
I was dreading find this reply.
