DIY: How to change center wheel caps!
Old 11-25-2015, 01:56 AM
lee16's Avatar
2010 E550
I noticed that one of my wheel caps had fallen apart. So here is a simple DIY on how to change your center cap.
Tools needed: 1. Knife
2. Center cap (Part# A 171 400 01 25 5337) for 2010 E550. (your center cap may vary)
DIY: How to change center wheel caps!-img_9242_zpsf9oh5d2y.jpg
Take your knife and pull off the center cap.
DIY: How to change center wheel caps!-img_9240_zpsb5na0tmh.jpg
As you can see in the picture, the new center cap needs to be pressed in.
DIY: How to change center wheel caps!-img_9243_zpstbndyjih.jpg
Align the center cap to the rim.
DIY: How to change center wheel caps!-img_9244_zpsnxvewot3.jpg
Press in until it's completely inserted.
DIY: How to change center wheel caps!-img_9245_zps1pwni3en.jpg
Done!
DIY: How to change center wheel caps!-img_9247_zpsa6rkjyaa.jpg
Old 11-25-2015, 03:26 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'09 C300 4matic,'15 GLA250,'07 Honda Odyssey, '18 GLE 43
Rather than sticking a knife between the cap and rim and scratching the rims in the process I would just get a drill bit make a hole on the cap and use hook to pull it out (this only works if you will never use the cap again).
Old 11-25-2015, 09:51 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
I noticed that two of my center caps have a "growth" on them I'm going to have to replace them.
Old 11-26-2015, 05:56 PM
Count Laszlo's Avatar
'16 GL550, '12 C350
A very thin flat head screen driver with a thin cloth around the front also works and you will not scratch your rim in the process of changing the caps out. My wife's car caps needed to be changed out last year. The original caps were made differently than the replacement caps, hense a defect in the originals which Mercedes changed at some point.
Old 12-02-2015, 01:09 PM
DuckySaysQuack's Avatar
2009 C300 4Matic Sport
I'm in need of doing this too. All four of my caps look like this (maybe not so bad). I've seen a set of these caps online for $60. Any idea where I can get some that are cheaper? Seems silly for plastic caps with silver paint on them...
Old 12-03-2015, 12:00 PM
white46's Avatar
08 C300
That's how mine, all 4, looked like.
Since the OEM caps didn't last long, I've purchased replica caps on ebay and happy with the result.
Search for "Mercedes-Benz Wheel Center Cap 75mm" on ebay.
Old 12-04-2015, 03:17 AM
edgalang's Avatar
Factory ordered 2012 MB C350 w/Dynamic Handling Package
I'm sorry but is this amateur hour?
The official way is to take the wheel off and pop them from the back. This is what any professional tire shop is going to do before they mount and balance a wheel.
What's next, are we going to start advising members it's ok to torque wheel bolts by feel?
Old 12-08-2015, 11:48 AM
Seems silly to take the entire wheel off if you're replacing caps that are bad and are gonna be thrown out anyways. I think if you're careful about not scratching the wheel you should be okay.
Old 12-08-2015, 01:50 PM
FlatlineEF9's Avatar
1996 E320, 2018 Ducati Panigale V4S, 2012 1199 Panigale
LOL
Quick Reply: DIY: How to change center wheel caps!
