Class Action extending 10 yrs or 125K
C230 is exhibiting rough idle, limp mode. already checked all coil packs, replaced sparkplugs, replaced maf sensor, swapped coils packs, replaced battery and it is still giving me errors 4,5,6 misfires. I am wondering if the settlement for broken sprocket for timing is causing any of this? I assume the error codes for these would be different than for misfire? Or is it possible that this precursor to taking it on to MB dealer?
Fuel pressure 55 psi steady
new plugs all NGK
clean air filters
checked all hoses for damage
Still have car parked and wont go over 10 mph unless you mash pedal even then it will not go.
new plugs all NGK
clean air filters
Last edited by jnino944; 02-09-2016 at 01:35 PM. Reason: wrong forum wheres the delete button???
If you have an '06, then it would be a W203, not a W204. Please repost in the correct forum
