5w-40 vs 0w-40
5w-40 vs 0w-40
I figured I'd post and see what people say...
So the dealership has used 5w-40 synthetic oil on my car since 2012.
is it possible to change back to 0w-40 for my next oil change or is it not recommend?
I'm doing my first DIY Mercedes oil change next week, and just wanted to know before I go buy the oil.
I was thinking stick with the 5w-40 synthetic oil but if its better and possible to change back to the recommend Mobil 1 0w-40 synthetic oil i will do that.
Looking forward to all the responses
Once you go synthetic, stick with it. But if you are just changing viscosity, you should be fine. The only thing I would plan is a mid point oil change just to make sure you get all of the 5w out. Lots of great posts out there about oil theories. Just takes a little digging.
I might change to the recommended 0w-40 and drive maybe 8000KM roughly 5000miles then do the change again.
I'm just having a hard time deciding..... is it really worth it? hahaha
No problem changing viscosities what so ever. My car has been dealer serviced since new with M1 5W-40(BTY, hard to find-the 0W-40 is plentiful)). I went with Castrol 0W-40. Either brand or viscosity is excellent. All have MB approvals.
0w-40 is more expensive but I'm not concerned to much about price i'd rather get whats best for the car.
The 0W-40 is stupid cheap at WalMart in the US.
I did my car just after I purchased it since CarMax performed one after the dealer did one for the previous owner. I had no idea what CarMax used so I decided to just change it out. They could only say it was synthetic.
I'm thinking of doing a partial change so I can add in some liquid moly.
I was thinking stick with the Mobil 1 5w-40 synthetic oil but if its better and possible to change back to the recommend Mobil 1 0w-40 synthetic oil i will do that.
Where are you finding the Mobil 1 5w-40 that's 229.5 approved? I can't find it anywhere..either way, Mobil 1 0w-40 has been good for me. Changing viscosity is no problem at all, as long as the oil is on the 229.5 approved oil list
If not, most of the Canadian tires have 4.4L jugs for 51.99/each. Sometimes they go on sale for 31.99 each and I usually buy a couple
I just had my Service B oil change done and I believe they used 5w-30 as usual, did I goof by not going with 0w-40? Is it a noticeable difference in way the car drives? I it really that much better? I'm in California, so the temperature doesn't get too low or high.
Mobil 1 5W-40 is a low SAPS oil that meets MB 229.51 which is their diesel oil specification. Oils meeting MB 229.51 can also be used in gasoline engines which is why dealers generally only stock the 5W-40. However, for optimum protection in gasoline engines, a full SAPS oil that meets MB 229.5 like Mobil 1 0W-40 is preferable. Mixing them when switching is inconsequential, as they are fully compatible when mixed.
LOL, that's every Internet car thread!
I'm thinking of doing a partial change so I can add in some liquid molly.
The same company also makes a ceramic based anti-friction lubricant but, according to the company, it could potentially cause issues with spark plugs in poor engines. So it has been popular in diesel engines.
It's a German company and has a history of use in German cars.
In the end, evidence shows it works and is not harmful. But is it necessary? Probably not as the engine may already outlast the car. However, we are in a thread debating 0W-40 vs 5W-40.
There is some controversy about it's effectiveness that gets debated with evidence from both side of the argument. I haven't tried it yet as I am still researching.
Bob is the Oil Guy has plenty on it as a starting point.
The differences in required formulation have little to do with wear and everything to do with meeting diesel emissions requirements and protecting the emission control systems on diesels.
Why not use the correct oil ?. Do you know more than the oil company labs ?
Did you even read my previous posts? The optimum oil for a Benz gasoline engine is one listed under MB 229.5. The only oil approved for a diesel Benz engine is one listed under under MB 229.51, although an oil meeting MB 229.51 can be used in a gasoline Benz. I'm frankly not sure what point you are making. All of my posts on this topic have suggested using M1 0W-40 as the optimum choice in a gasoline engine, and that dealerships use M1 5W-40 because they can stock one oil that can be used in both gasoline and diesel engines even though it is less than optimum in the gas engines. They are both "correct" oils for gasoline engines, but the 0W-40 will provide better protection in gasoline engines. No, I do not know more than "the oil company labs" (sic), but clearly I know a lot more about tribology than you. MB 229.51 requires a low SAPS (sulfated ash, phosphorous, sulfur) formulation to protect diesel emission systems which are damaged by a high SAPS content. However, a high SAPS oil formulation provides better wear protection. In order to compensate for the low SAPS anti-wear deficiencies, oils used in modern diesel engines include extra quantities of friction modifiers to compensate for the lower SAPS content. In addition, oils optimized for use in diesels typically have higher TBN levels to maintain engine cleanliness in the presence of the soot produced as a byproduct of diesel combustion. I have greatly over simplified what is a very complex subject, but a basic explanation of the differences between the two formulations appears to have been necessary.
Ferris_E550 (04-07-2018)
.[/QUOTE] Quote:Originally Posted by BerndV View Post
.[/QUOTE]
Thank you, finally. The 229.5 will provided better protection for petrol engines.
I would not let a slack dealer put the 229.51 in my petrol engine.
.[/QUOTE]
