Parking light housing broke
Old 05-19-2016, 09:39 PM
Hu.Ag1124's Avatar
c300
Hi guys, so i was trying to upgrade my parking lights to leds and in the process as i went to pull out the bulb, the housing broke and came off with the bulb, i was thinking about removing the headlight and try to glue it back together. did anyone ever encounter a similar issue? or would anyone be kind to give me some advice on this matter. please and thank you
Old 06-16-2016, 10:15 PM
Uncle's Avatar
2010 C300
Same thing happened to me, the tube part of the housing on the headlight assembly broke.
Old 06-18-2016, 05:02 AM
diabeelek's Avatar
W204 220CDI '07/2009
I have this same problem with all(four) bulbs.
So if somebody find solution will be great, because I don't want buy new headlights...
Old 06-23-2016, 05:29 AM
Hu.Ag1124's Avatar
c300
I removed the headlight completely and glued the broken piece back in and its been working fine so far, been a couple of weeks
Henry Bondi (11-02-2020)
Old 06-23-2016, 05:39 AM
diabeelek's Avatar
What a kind of glue you used?
Old 06-26-2016, 10:41 PM
Hu.Ag1124's Avatar
c300
i mixed up gorilla and super glue
Old 11-02-2020, 07:13 AM
Henry Bondi's Avatar
2010 C-Class CGI W204
Parking light housing broken
Seems to be a common problem, I was trying to remove the wedge bulb, thing couldn't even budge..broke the housing and still couldn't separate the two. Had to replace bulb and just put the broken piece back in place. I'll have to get some time to remove and glue it on. And possibly gently check housings on other headlamps..seems over time the plastics get brittle
Quick Reply: Parking light housing broke
