2011 C300 Sport Wheel upgrade
2011 Mercedes C300 Sport
Greetings, new MB owner and new to the forum.
I was looking to upgrade the wheels and tires when the current tread is gone on my existing.
I wanted to find out if anyone could shed some light on wheel upgrade compatibility, I found some 2015 AMG wheels with Continental tires already mounted.
#1 - does anyone know if these will fit on a 2011 C300 Sport (W204)?
#2 - Tire Pressure Monitoring System - what do I need to do so that it will work?
if there are any existing threads, please send links, it would be greatly appreciated.
Wheels I am looking to acquire:
http://www.ebay.com/itm/2015-Genuine-OEM-Factory-Mercedes-Benz-AMG-C400-18-inch-WHEELS-TIRES-Set-C300/201443732532?_trksid=p2060778.c100276.m3476&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140725133649%26meid%3D4d288ec3d2cf428d83f23106106d46b0%26pid%3D100276%26rk%3D1%26rkt%3D4%26sd%3D381584666596
Subaru Impreza RS, Mazda CX-5, C250 Sedan
It should fit no problem. But you can check the wheel/tire size to see the difference by entering size/offset/width. You can just google those tire/wheel size calculator etc. Some even show you how much the difference in visual. Any parameter changes more than 3% will be a concern.
For the TPMS, you will just take the one off from your current wheel and install it onto the new wheels. The tire shop knows what to do.
Hope this helps.
Hope this helps.
