Right Mirror Turn Signal
Hey guys,
It seems like my right mirror turn signal is sometimes out but then sometimes working correctly. It will blink faster and give me a "Check Right Mirror Turn Signal" notification but then sometimes it will work normally. Is this normal if it is going out or is there another issue that is causing this? Figured I would see if anyone else had any experience with this.
It seems like the front and rear blinker work normally (like they do not speed up the rate at which they blink at) but just the turn signal on the mirror is faulty and does not blink. I thought about ordering a replacement and swapping them out.
Mine did this on my old C-class and all it took was a replacement of the mirror repeater. The connections had some corrosion. I do not believe this is an expensive part or a difficult DIY. Not sure why the immediate suggestion was SAM - that is extremely unlikely.
Hmm... This repeater... Where might this be located?
