Why me. Help tire rub issue
guys so I just had set of new tires put on my 507 and the fronts are rubbing the strut. The fronts are star spec 245 40 r19, rears 275 .. I read a few people on here were running that size on the fronts.... it tore up the tires already pretty bad( not even 2 miles on them ). Any thing I can do to fix it or do I need to buy a Fing new set of fronts. Why me... lol
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Aw dude, that sucks.
You're tires might be done but I'm not a pro so someone else will answer it for you.
Anyway, for future reference you can also post here: https://mbworld.org/forums/c63-amg-w204-93/
Good luck!
Good luck!
2014 C63 AMG 507 sedan
Wrong tire size
Your tire specs are larger than OEM specs. Front tires are a 35 series in the front and 30 series in the rear. The correct spec should be 245/35/19 front and 275/30/19 rear.
