2009 C350 - Climate Control Reset Procedure
Does anyone know the procedure to reset the climate control??
I've had no heat in the car when suddenly it came on. At idle it was weak but during driving it came on fine.
You have been reading all the HS at Bens Wurld---there is no reset procedure!! Find an indy with factory or equal diagnostic software and they will have a solution in two minutes---then you can attempt to repair the car!!
