Hand Brake
Old 12-01-2016, 07:10 PM
mrtomq's Avatar
2012 C250
Hand Brake
My foot brake won't lock when I step on it and the hand brake lever has no resistance. How do you repair this?
Old 12-02-2016, 12:57 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Post your VIN!!
Old 12-12-2016, 05:10 PM
mrtomq's Avatar
2012 C250
Anyone who has worked with foot brakes? I can't engage my foot brake.
Old 12-13-2016, 03:17 AM
shadenfroh's Avatar
A member with thousands of posts and hundreds of "thanks" received gave you a simple direction. I have a feeling that you may get some help if you answer him.
Old 12-13-2016, 12:57 PM
mrtomq's Avatar
2012 C250
Originally Posted by Plutoe
Post your VIN!!
WDDGF4HBXCR215367
Old 12-13-2016, 01:57 PM
tpliquid's Avatar
C63, GT3RS, 430 Scud, E63, CGT
looks like maybe u need to adjust the drum brake in the back
Old 12-13-2016, 02:32 PM
mrtomq's Avatar
2012 C250
The handle itself does not have any tension - like spring broke or something. I step on the foot brake but it does not stay in place. Above the handle are 2 screws which I am very tempted to remove to see what's behind it.
Old 12-14-2016, 02:06 PM
shadenfroh's Avatar
Does the brake itself engage? If the car is rolling and you press it?
If you try adjusting your parking brake, keep in mind that it's not done by messing with the strings. You take a lug nut out, rotate the wheel till you see an opening with a little cog wheel inside, tighten it till the brake "bites" and back off four clicks.
Here's a photo of the assembly. You can see the leaf spring and a ratcheting mechanism which seems kind of flimsy. Both could be at fault.
Old 12-14-2016, 04:03 PM
mrtomq's Avatar
2012 C250
Thank you for the reply. The footbrake does not engage. I have a feeling the leaf spring came off or one end of the cable.
Old 12-18-2016, 02:24 AM
shadenfroh's Avatar
Any progress?
Old 12-18-2016, 02:33 AM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
the cable to the brake bay be broken, or the parking brakes may be seized. I'd put my money on the cable or pedal mechanism, it'd be surprising for both sides of the parking brake to completely seize at the same time. The brakes are basically drum shoes that make contact with the inside of the rear rotor hat.
Quick Reply: Hand Brake
