2016 18" S63 S550 fit C300 4Matic?
2011 C300 4Matic
Model # :185112ME140GMMF
Bolt Pattern :
Offset : 35
Wheel Size :F- 18x8.5 R- 18x9.5
TPMS Compatible : Yes
Wheel Fitment :All Mercedes S Class E Class, CL 4Matic & AMG Models
Quantity : 4
Center Caps :Included
Condition : Brand New
Bolt Pattern :
Offset : 35
Quantity : 4
front 245 40 18 rear 255 35 18 and you will need a rear fender stretch for 8mm
i have same size rims and thats what you need .
right offset is et45 not et35 thats why you need fender stretch
2011 C300 4Matic
I currently have 18x8.5+45 fronts and 18x9.5+45 rears. IMO the fronts are perfect, but the rears should be +50.
With 18x9.5+45 rears I am unable to put on 265/35-18 PSS without rubbing on full load.
I would also NOT go with a 245/40 & 255/35 combo (since the circumference difference is too high), especially since you have a 4Matic.
2011 C300 4Matic
What tires' sizes you have now?
2011 C300 4Matic
Thanks.. I was thinking about Tire (R) should be 265/35/18. Possible?
2011 C300 4Matic
2011 C300 4Matic
How many MM do i need to add to +35? make it +45?
Spacers lower the number not raise it. If you add 10mm spacer it will turn 10mm closer to 0, so 25 offset.
This is a reason why you can use a wheel with a high offset like 45 on a car that comes with say 35, because you can add spacer to bring it to spec as long as it doesn't rub on the outside. Now if you have low offset wheel say 35 on a car that runs stock on 45+ offset, then it will stick out a lot and rub unless you go extremely conservative on wheel width.
2011 C300 4Matic
Got it! Thanks
2011 C300 4Matic
2011 C300 4Matic
