Any tricks on replacing a W204 battery?
Old 01-11-2017, 09:46 AM
2012c350's Avatar
2020 C363 S / 2007 SLK55 / 2016 F150 4x4 / 1998 Cobra Convertible
I want to replace the battery on my 2012 C350. When I was picking up a battery for my son's Ford at Advance Auto, I mentioned this to the guy there and he said I can't do it myself. He claims that the MB needs to have voltage running to it and that if I remove the old battery and put in the new (like I've done in all other vehicles) that it will need to be taken to the dealer to be "reset." Is this true? I was hoping it was as simple as the older American cars I've worked on. I did a search and don't see this already answered, so apologies if this is a common question.
Old 01-11-2017, 11:17 AM
Colin G's Avatar
2008 C-230 4Matic Sport
Not true.
Remove old battery and replace with new one.
You may have to reset some of your settings in the car like radio presets ect.
Took me 10 minutes to change my battery.
Old 01-11-2017, 11:39 AM
Colin G's Avatar
Oh, I did buy one of those devices that plugs a 9V battery into your cigarette lighter to "save" your car's presets when the battery is disconnected. Was about $8 and was a complete waste of $8 so don't buy one.
Did not work worth a damn so I returned it.
Old 01-11-2017, 12:03 PM
rander's Avatar
2010 C300 4Matic Sport
I think the reason your gadget that plugs into the cigarette lighted didn't work is because the lighter is not powered when the ignition is off and key removed.
Old 01-11-2017, 12:09 PM
Colin G's Avatar
You may be right!
I did not try that thing in the outlet in the glove box, just the cigarette lighter receptacle.
Cig lighters worked in all my other cars when the car is not running so I assumed the same for my C230.
Old 01-11-2017, 03:45 PM
2012c350's Avatar
Thanks all. Some google searches talked about "some newer BMW/MBs" need to have the battery registered with the car so that it doesn't try to overcharge a newer battery, basically saying that the car is programmed the type/age/etc of the battery. But from the comments here, and other searches, it sounds like I was hoping...just disconnect, replace, connect. Thanks again!
Now to decide if I want to go OEM or try the Exide that someone else just recently posted. But that'll be a flip of the coin.
Old 01-11-2017, 03:55 PM
Colin G's Avatar
If price is not too much of a concern I really Like Odyssey or NorthStar batteries. Same company.
When I was looking for a good battery I googled Exide and found a lot of unfavourable reviews.
Old 01-11-2017, 06:25 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Make sure you fit an AGM
Old 01-12-2017, 07:43 AM
2012c350's Avatar
Thanks for the recommendation. I'll check them out.
Old 01-12-2017, 12:02 PM
M~Factor's Avatar
2017 AMG GT, 2015 ML350, 2013 C300
Walmart's EverStart Maxx batteries works just fine.
  • 5 Year Warranty Program (3 Years Free Replacement + 2 Years Prorated)
  • 790 CCA (Cold Cranking Amps)
  • $150.13
Old 01-12-2017, 02:37 PM
Carsy's Avatar
Make sure you fit a AGM with a recent date stamp.....
Are Walmarts Everstart AGMs?
Old 01-13-2017, 02:17 AM
Demvang's Avatar
2011 C300 4Matic Sport
Mine's a Duralast Gold from Autozone. 14k miles so far.
I read some posts stating that they had problems after installation. To have a smooth battery replacement, I just hooked a 12v 9a battery while disconnecting.
Old 01-13-2017, 10:00 AM
M~Factor's Avatar
Yeap. Everstart Platinum AGM H7 for $164.86
Old 01-13-2017, 01:02 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The cig lighter in my car is powered with the ignition off and key out. FYI
Old 01-13-2017, 09:12 PM
95_993's Avatar
C300 Sport
I went with Interatate. Direct fit....easy. Took 5-10 mins tops
Old 01-15-2017, 11:50 AM
varelchik's Avatar
W204 C200 CGI
also during a battery changing process don't leave the key in the ignition switch!!! in some case this will lead that your mb "lost" your key
Old 01-15-2017, 02:33 PM
Carsy's Avatar
Good thinking
Old 01-15-2017, 10:00 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera. 2002 QX4
I bought from dealer the original battery. Installation is straightforward.
Old 01-16-2017, 11:28 AM
Atlas Grey's Avatar
2005 Porsche 911, 1991 Jeep Grand Wagoneer, 2012 Mercedes C300 4Matic
I swapped out the battery in my wife's C300 with a Bosch AGM and there were no issues
Old 01-17-2017, 08:48 AM
Rander101's Avatar
Mercedes C300 Sport 4 Matic
That's interesting. I just went and checked and on my 2010 C300 Sport and the lighter is not live when the key is out. My old 97 E320 was the same way.
Wonder when and why MB changed things?
Old 01-17-2017, 02:51 PM
LILBENZ230's Avatar
Dealer wants $310 to replace my battery in my 2014. My complaint was that eco start/stop hardly functions anymore and sometimes is unavailable altogether. I thought this system was ran by the aux battery in the trunk, but they insist the can't proceed with diagnosis until I pay the $310 to replace the under hood battery.
Old 01-17-2017, 02:58 PM
Carsy's Avatar
1. A 2 year old battery should not fail.
2. They should load test your battery. They are the dealer with all the diagnostic equipment.
3. Why can't they pull a battery out of another car that has no symptoms.
4.If you do buy a new battery make sure you replace the old one if it turns out to be OK & sell the new one.
5.They are ripping you off. See the recent posts re battery prices.
The best of bleeding luck.
Old 01-17-2017, 03:09 PM
Atlas Grey's Avatar
Agree with Carsy, them charging you upfront without even testing your battery is stupid and a 2-3 year old battery should really be ok unless you are Minnesota or Arizona. I just replaced my wife's 11's battery after 6 years of service. You can take your battery out and take it to either Pep Boys or Autozone for a free check.
Old 01-17-2017, 06:58 PM
nicholasyud's Avatar
C300 2011
2 years old car battery should cover under warranty or road side assistance. I call dealer for my 2011 c300 and they give me a discount for $137 brand new battery. Much better than the one i buy on ebay that i had to return it.
Easy to install. Watch some youtube. 12mm socket i think.....
Old 01-20-2017, 12:53 AM
LILBENZ230's Avatar
Plot twist.
I bought the car used with 24k miles back in May 2016. The car has never had issues with electronics, except for the eco start/stop being weird when it is really cold out. I said the same thing - the car has 37.5k miles, no other electronic issues, can't you pro-rate a battery?
The car has an aftermarket battery already. Not sure what happened it is early life to ruin the original battery. But all of this is beside the point, really. Is the eco start/stop not ran exclusively from the aux battery?
Quick Reply: Any tricks on replacing a W204 battery?
