W204 Front Shock/ Strut. Advice needed.
Old 02-15-2017, 07:13 PM
SeanMGibson1835's Avatar
Mercedes-Benz C300 4Matic Sport
Talking W204 Front Shock/ Strut. Advice needed.
Hey guys, New here!
After a nice long winter up in the north east, the potholes finally got me. The front passenger side shock absorber needs to be replaced. I know that I need to replace them in pairs and have the means to do it. However the thing I'm having trouble with is finding a complete front replacement. I can't seem to find anything other than just the coil, or just the strut. If anyone can offer incite on where I can find an complete replacement it would be greatly appreciated.
Old 02-15-2017, 09:42 PM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
I had the same problem and couldn't find any full assemblies, and I assume it'd be $$$ if I did. Ended up buying all the pieces individually and having them assembled by a shop before I installed them in the car. Unfortunately, there's no easy way to DIY assemble the struts. Regular spring compressors, I can confirm, do not work
Old 02-16-2017, 10:19 AM
M~Factor's Avatar
2017 AMG GT, 2015 ML350, 2013 C300
How about an aftermarket coilover that is comparable to OEM ride quality?
Old 02-16-2017, 10:45 AM
Funkwagen's Avatar
4matic w204s have very limited aftermarket options for coilovers.. The only compatible kit I know of is KW v3 coilovers. Which are quite pricey
Old 02-16-2017, 11:22 AM
tekfoc's Avatar
18 E63S
GET SOME B6 Bilsteins hd struts really excellent for east cost pot holes
I have them standing by in my closet for when the replacement from Mercedes ware out. I'm ready.
Funkwagen (02-16-2017)
Old 02-16-2017, 01:13 PM
Funkwagen's Avatar
How much did you pay for them?
Old 02-16-2017, 02:36 PM
tekfoc's Avatar
18 E63S
https://www.fcpeuro.com/products/mer...c350-35-170815
or get the sale from here
I purchased the rear b6 shocks from them
http://www.ajusa.com/2012-Mercedes-B...21eq139a8.html
Old 02-17-2017, 09:23 AM
Originally Posted by SeanMGibson1835
Hey guys, New here!
Thanks for the help. I've been looking on eBay for some quality used OEM replacements. Found some for about 175-200. But I might end up just going with the Bilstein's. It's a toss up right now. Figure if I'm doing the front I might as well do the back while I'm at it.
Old 02-17-2017, 09:26 AM
Colin G's Avatar
2008 C-230 4Matic Sport
I will be buying those also when the time comes.
Pot hole central up here too.
Old 02-17-2017, 09:31 AM
Colin G's Avatar
AJ USA price is good. Too bad no shipping to Canada.
Old 02-18-2017, 04:16 PM
Just204's Avatar
Mercedes w204 4matic sport
if you don't mind used, you can get a strut assembly cheap here; car-part.com. I've used the site before.
Old 04-17-2017, 08:19 AM
JWH321's Avatar
2008 C300 Luxury
Can you elaborate a bit on why the regular spring compressors would not work? I'm hoping to do this in the next week or so.
Old 08-21-2017, 09:14 AM
tekfoc's Avatar
18 E63S
bringing this back
I just replaced my struts with the B6 bilsteins struts and used harbor freight sizer spring compressor .
was a real pain in the ***.
once you remove the spring you must release spring from compressor and then reset it back on to a higher part of spring coil to get it compress far enough for the strut mount to be bolted back on.
I highly suggest that people bring the strut to a shop and let them use there compressor.
then bring it back to your car and mount it. very easy to dismount and mount struts back on the car.
sure enough the stock struts that was replaced from Mercedes a year and half was worn out already.
easy to compress on floor and both struts were making loud squeaking noises when I compress them on the floor.
freaking sachs stock struts are garbage.
this is what i used .
https://www.harborfreight.com/automo...sor-43753.html
Old 08-22-2017, 01:25 PM
Tom in Austin's Avatar
2016 S550, 2015 Honda Civic Hybrid
I just put Koni FSDs on my 11.5k mile 2014 C350, and getting ready to sell the OEM sport struts/shocks.
PM if you'd be interested in going this route.
Old 06-13-2019, 11:17 AM
Nicholi2007's Avatar
2009 C350
If I replace the fronts with these, can the rear wait? Or do you need to do it all at once?
Old 06-13-2019, 12:46 PM
tekfoc's Avatar
18 E63S
Sure can that’s what I did .
I changed out the fronts to b6 struts and held off installing the rear shocks cause they were still good for the mean time.
performed well.
I no longer own my W204 traded in.
Nicholi2007 (01-17-2021)
Old 06-24-2019, 03:25 PM
2009 C350
performed well.
As for replacing strut mounts, is there confusion? I only thought the strut bearings went.
I get replacing the bolts. Not sure about the strut bumper but probably a good idea...
Old 06-24-2019, 03:37 PM
tekfoc's Avatar
18 E63S
I get replacing the bolts. Not sure about they strut bumper but probably a good idea...
Do your self a big favor
always replace the strut mount with a new strut mount bearings.
Include all hardware.
original strut bumper stops must be removed and not used on B6 bilsteins because the B6 struts have internal bump stops .
Old 06-24-2019, 04:59 PM
2009 C350
I decided to stay with B4 for now. I got a great deal at $268.17 shipped, no tax.
Car has 122K. replace strut bumpers too? I just hate replacing stuff unless it's absolutely necessary....
Old 06-24-2019, 07:30 PM
tekfoc's Avatar
18 E63S
I have no idea if the B4 bilsteins struts have internal bump stops .
you need to find out .
Old 01-23-2022, 11:59 PM
chabbs93's Avatar
c250 W204
did you change the bumpers?
Old 01-24-2022, 03:08 AM
Gazwould's Avatar
S204 C250 CDI Sport
Mercedes OEM is Bilstein in this application and they are not ordinary dampers as they are dual rate.
Bilstein B4 DampMatic
https://www.aftermarket.com.au/bilstein-b4-dampmatic/
