C400 tire Help
2011 E350 Bluetec
C400 tire Help
I just got these rims from a friend of mine and I am considering them to use them on my 2015 C400 (With Sports Package)
These are AMG rims for CLS
Front alloy wheels: 20x8.5" ET43
Wheel part number: AMG B66031197
Additional alloy part number: A2214013302
Rear alloy wheels: 20x9.5" ET43
Wheel part number: AMG B66031198
Additional alloy part number: A2214013402
I would like to know which tire size will be the perfect fit. I just want to clarify that I am at stock height and have no intentions of lowering the car.
Your help in this matter will be highly appreciated.
Regards
Shaq
Regards
Shaq
Administrator
You start out with your OEM tire/wheel sizes and then do
a) simple math
or
b) plug them into an online tire/wheel calculator
to arrive at your answer.
a) simple math
or
Try www.tirerack.com and look up your car.
Edit: just checked. Car is too new, no recommendation other than O. E. sizes. Usually if you look up available rim sizes, it tells you what should fit the 20s.
Just go to any online tire size calculator.
