Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tire Repair and Maintenance
- Mercedes Benz C-Class: Tire Pressure Monitoring System
Important information to help you understand your Mercedes-Benz
Factory recommended tyre pressure for 19" wheels
W205 C250
To owners who have the 19" AMG wheels package as standard, can anyone post a picture of the factory recommended tyre pressure as stated on the fuel filler door?
My W205 comes with 17" wheels as standard but I will be upgrading to the multi-spoke 19" AMG wheels which are arriving this weekend and would like to have this info for reference.
Your help is much appreciated and thanks in advance!
PS: My dealer doesn't know of this info as all W205's come with 17" wheels as standard and no further option available
galileo55 (08-31-2018)
My advice is to inflate to the higher of those two settings for tire pressure on the 19s. So nice I did that the car handled much better, rides better and slightly better fuel consumption.
My C300 came with 18 inch staggered runflats and has the same sticker under the gas flap. I ran the higher pressures although I rarely had a maximum load. Toward the end of the tires usable life, just under 20K miles, I noticed that the rears showed more wear in the center of the tires indicating the pressure was higher than it should be. I am now running non runflats and have lowered the rear pressures to 39-40 psi. Front tires did well at 39 psi.
