AMG Style Door Pins
Old 02-26-2015, 10:27 PM
Seanix's Avatar
Mercedes C250 (W205)
AMG Style Door Pins
I bought a set off the AMG style door pins as I didn't like the cheap looking plastic ones that the car came with. I tried unscrewing the old ones but couldn't get them to budge, and I don't want to force them incase I break or damage something.
Does anyone know how to safely remove the plastic pins? Do I need a padded pair of vice grips to crack the glue holding it in place? Or do I just need to gain some more muscle?... lol
Old 02-26-2015, 10:55 PM
bartola's Avatar
CLA-250, C-300
They unscrew, they are screwed pretty good (by robots I assume), I got a set of AMG ones from ebay for my CLA, same grey ugly plastic ones had to go.
Old 02-26-2015, 11:27 PM
Diamondburn's Avatar
C400 4MATIC, AMG Sport Package, Panoramic Sunroof, Airmatic, 19" AMG bi-black rims, Tinted windows
Sean did you buy your pins from eBay as well?
Old 02-27-2015, 02:10 AM
yObOyGeo's Avatar
C400
theres no glue in them. they are just tightened well, use regular pliers and a reg or a sock .. the rear ones are tricky as the door blades have to be removed for the pins to be replaced
Old 02-27-2015, 10:26 PM
yObOyGeo's Avatar
C400
i retract that statement the rear pins are screw in just like the front ones ! adn are the same size as well ! Guess whos ordering a set of 4 AMG genuine Door pins ?!
Old 02-27-2015, 11:26 PM
vistec's Avatar
TBD
We're you able to actually screw them off? I have had people tell me that the door panel has to be removed to take the pins off.... Don't a want all that trouble just to change pins...
Old 02-28-2015, 02:58 AM
Seanix's Avatar
It was pretty easy to remove and install the new door pins. Pair of needle nose pliers and a sock easily and safely did the trick
Not sure that the pics do them justice, but they look fantastic on!
Old 02-28-2015, 06:44 AM
Mr Enigma's Avatar
MB W204, VW Polo, Audi R8 V10 - SOLD.
Was that for both front and back? So no panel removal for the rear pins?
Edit: I just read the last few posts and it looks like it is just a screw off/on job. Thanks for the pictures.
Old 02-28-2015, 07:04 AM
floridadriver's Avatar
2015 C300 RWD
Looks nice! Thanks for pics.
Old 02-28-2015, 10:50 AM
yObOyGeo's Avatar
C400
Looks nice man congrats, But i hate the look of the FAKE AMG pins, theyre too shiny and chrome. The real ones look more brushed aluminum, theyre very similar but its not as shiny
Old 02-28-2015, 11:34 AM
vistec's Avatar
TBD
So you can confirm no need to remove the door panel?
Thanks in advance
Old 02-28-2015, 12:54 PM
notabenex's Avatar
C63 W205 17' + W205 C250@brabus + NSX 95'
Where to buy it?
Old 02-28-2015, 06:51 PM
Seanix's Avatar
No need to remove any door panels... Simply unscrew pins (front and Back). Pins are the same front and back. Very simple to do and will only require around 15mins
Only difference I found was that the new AMG style pins were about 5mm smaller than the original ones. It didn't seem to make any difference for functionality, but aesthetically I think it looks a bit better as they don't stick up as much...
I bought the AMG pins from eBay for around $130 (AUD)
Old 02-28-2015, 07:13 PM
TensaZ's Avatar
2015 C300
Do you simply turn the pin anticlockwise to unscrew the plastic pins?
I tried with reasonable amount of force but it wouldn't move. I'm a bit worried that I may break it...
Old 02-28-2015, 08:15 PM
Seanix's Avatar
They turned in an anti-clockwise direction and are on pretty tight, but with my trusty pair of long nose pliers and "sock" I manged to budge them without damage to the originals. Maybe try the others first as I found 2 out of the four I was able to turn them without using the pliers....
Old 03-04-2015, 10:26 PM
yObOyGeo's Avatar
C400
does anyone know how much higher does the rear stick out the the front ?
Old 11-10-2016, 01:07 AM
rparamount's Avatar
Mercedes Benz C450 AMG 4MATIC
I just bought the door pins and they are great. I removed them using a wrench and a small towel. That allowed me to remove them without damaging anything. Just unscrew counter-clockwise. There was no need to remove door panels.
-RP
Quick Reply: AMG Style Door Pins
