Has anyone used the emergency key on the door?
Had my first no response with Keyless Go today. It wouldn't unlock the door, even after pushing the unlock button on the fob. I waited about 2 minutes, it reset itself, and all was normal again. So, I thought this might be a good time to review the emergency key unlock routine.
The digital manual shows a small slit on the side of the door handle, and you're supposed to insert the tip of the emergency key and move the cover to reveal the key slot under it. On my car, that slit is under the handle. I inserted the tip of the key, tried turning it, and nothing would move at all. I did not want to force it, but I saw almost no movement of the portion of the handle that the slit was on. The key slot under the trunk lid works fine, but that of course doesn't unlock the door.
Has anyone figured out how this is supposed to work?
2015 C400
Apologies for the silly question, but are you sure you don't have that slit to the right of the handle? It looks like a fake key hole. I can't imagine MB would go through the trouble of making multiple key holes for the same car model.
But it's as you described. You put the key tip from the fob into it and turn. Turn it a complete 360 and the cap will come off to display the actual key hole (I'd be prepared to catch it).
And if the manual is correct you can expect the alarm to go off until he key is in the ignition.
If pictures help let me know.
2015 C400
Maybe a picture would be helpful. i have the keyless go and this is what mine looks like. If yours doesn't look like this then I think someone has some explaining to do.
2015 C300 4MATIC
Yes. I do not have keyless-go though, When I picked up my car - my delivery concierge took me through the process and demonstrated the use of the emergency key. Also showed me how to pull the keyless start button and (heres the duh! part ... showed me how to insert the large key and turn it)
That's what the one on my last C300 looked like, but the one on my new C300 has the slot under the handle. There's an illustration of it on page 89 of the online owner's manual, but it's listed as the one used with non-Keyless Go. Either way, it doesn't seem to work.
I'm wondering if they put the wrong handle on the car, or if newer production cars are all using one key slot style now. I emailed MB-USA and am waiting for a response.
If you don't mind trying yours, I'd be curious as to whether or not you can get that cover off. I was afraid to apply much force.
I have those instructions, and it didn't work for me. The key goes in the slot, but I can't get the cap to pull off from the handle. I have tried it with holding the door handle out and without holding the handle out ... results are the same.
I may just leave this for my first service visit and let the dealer demonstrate how it does, or does not, work.
2015 C300 RWD Sport Premium
That's exactly what mine looks like, so I guess this is a later production change. Apparently, both Keyless Go and non-Keyless Go now share the same handle and emergency key access.
This really should be a simple thing to do, especially since you may wind up having to do it in the dark if your fob isn't working right. You shouldn't need a crowbar to force that cap off.
On my Jan '15 build, the slot is on the side (same as locking indentation). I used the emergency key, and after one half turn the little button cover can be pulled off exposing the key slot. I didn't insert the key, as I didn't want to startle the cat sleeping in the garage.
From those photos/manual instructions it seems MB made this more difficult in the newer vehicle.
Just looked at mine nothing like the photos I posted previously, I have keyless entry, there is a slot on the face of handle just put emergency key in and turn ie no cover to remove.
Very weird, indeed, All the US cars have the emergency key access covered by a cap which must be removed by inserting the tip of the emergency key. There are two different styles of release slots ... one on the side of the handle and the other under it. It seems the latest production now have the slot under the handle. These caps don't seem easy to remove. In the US, there is no reference to any direct access to the emergency key slot. Now, I am totally confused.
Went and took a look at what I have this morning...I have Keyless Go btw on and October '14 build.
I emergency key worked without any issues and it was super easy to get to and unlock. However, now that little plastic piece I removed won't stay in...I blame you guys!
2015 C400
This would only be needed if you can't get into the car with the fob, but it's nice to know it works if you need it. I guess, if needed, one could always pop the trunk using the emergency key slot under the lid, and then release the folding rear seats and get into the car that way.
My car is a late March, 2015 US build. I think the change in the door cap must be very recent since January builds still have the outside style.
2015 C400
CO2010 and I have the same style handle, which is not the same as others have. This style was originally described as the one that goes with the non-Keyless Go setup, but both of us have Keyless Go and we have this style. It will not allow the full insertion of the key. Supposedly, you insert the key tip, pull the door handle open and hold it, then pull the cap straight out. My door handle cap will not move, even with quite a bit of pressure, so I have no access to the emergency key slot hidden under that cap.
Also, with the old C300 I used the manual ignition several times. With the one incident on the new car, after a minute or so the doors unlocked and the push to start worked fine.
There really doesn't seem to be much logic here.
Success! I was determined to get this cap off today. You have to insert the emergency key all the way in. Instructions say to pull the cap off straight out, yeah that's not gonna happen. You will have to put some force into it but it does eventually come off. Door opens right away with the emergency key. Afterwards, the cap just snaps right back in.
I'll try it tomorrow. My manual says to only insert the tip of the key, which obviously is wrong. I'll bring a sledgehammer along just in case ...
Lol, I tried just inserting the tip but that didn't work. If you look at the last pic of the cap it looks like you just have to unlock that first tab so maybe inserting just the tip would work. Good luck
