My Mercedes C400 lowered on Vossen VFS1 airmatic
Old 05-25-2015, 01:54 AM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
First of all, thanks to VIC VIPER for all the tips.
Here is my car lowered with lowering links + airmatc on my C400
This is "sport+" setting, in comfort it raises about 1/2 inch.
In my opinion, installing the links is one thing, but you really should get someone with Xentry to calibrate and ensure that the sensors are all in range so you do not get any errors and everything is level and perfect.
Took many hours to fine tune it on a level surface but the results are amazing.
Still need to be careful around speedbumps.
Old 05-25-2015, 07:13 AM
RTX
RTX's Avatar
2015, W205, C 220 BlueTEC AMG Line
Do you plan to upgrade the brakes?
Old 05-25-2015, 08:28 AM
vic viper's Avatar
S213
Looking good!
Old 05-25-2015, 09:06 AM
JMES's Avatar
2015 C400
Nice Setup.
I'm in the GTA and looking for a similar set up. what offsets did you use? What Shop did your work?
Old 05-25-2015, 10:18 AM
angeloxnet's Avatar
not really, the brakes seem plenty adequate for the job.
the front rotars/calipers are huge!
Old 05-25-2015, 10:29 AM
omgitselaine's Avatar
Lexus IS 350 F Sport
I remember you from the W204 section back in the days and now you're here in the W205 !!
Love your ride .... looks greaat
Old 05-25-2015, 11:23 AM
Dkinsley's Avatar
C400
Looks very clean! This is one of my favorite looks. Do you mind giving the wheel/ tire sizes and offset? Currently trying to find tires for my setup and like to know what is working for others.
Old 05-25-2015, 01:51 PM
PeterUbers's Avatar
Received 1,886 Likes on 1,323 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
I'm glad it came out how you wanted it
That car would be totally undriveable the way you have it in the posted pic ... Where I live in the suburbs of Chicago
Old 05-25-2015, 10:29 PM
angeloxnet's Avatar
wheels are:
20x8.5 front 45 offset with a 5mm spacer
20x10 rear 55 offset with a 3 mm spacer
235/30/20 F and 275/25/20 R
Old 05-26-2015, 04:22 PM
realax's Avatar
g-wagon
looks clean & simple. amazing!
Old 05-28-2015, 12:10 AM
uptownman's Avatar
Past:2010 ML63 AMG, 2011 C63 AMG, 2011 E63 AMG, 2015 C400 4matic & 2014 CLS550 4matic. Now: 2017 C43
Very nice!
Is this stance possible with a non air suspension C400?
And any rubbing with the 20s?
Thanks!
Old 05-28-2015, 07:29 AM
angeloxnet's Avatar
not sure if this "look" is avail on non airmatic, i guess until we see more offerings from KW, H&R, eibach we'll find out.
Currently I have not rubbed on regular or spirited driving, however around speed bumps, driveway entrances i tend to go slow and on angles so I am careful.
Old 06-06-2015, 11:32 PM
angeloxnet's Avatar
another pic
Old 06-06-2015, 11:36 PM
angeloxnet's Avatar
Old 06-08-2015, 08:02 PM
floridadriver's Avatar
2015 C300 RWD
That looks hot man, and great pic. I also agree with you...Vic Viper is the bomb in my book..and a huge asset to this forum.
Old 06-09-2015, 10:05 AM
angeloxnet's Avatar
thanks for the kind words
Old 06-09-2015, 11:27 AM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
Nice - need larger pics!
Old 06-09-2015, 01:45 PM
LateC300's Avatar
2015 C300
stunning. great pictures.
also, what tint are you running?
Old 06-09-2015, 03:08 PM
angeloxnet's Avatar
15% all round
Pinnacle film
Old 06-09-2015, 03:59 PM
LateC300's Avatar
2015 C300
wow that's dark, looks really nice. i'd get pulled over in a hot minute around here
Old 06-09-2015, 04:53 PM
Former Vendor of MBWorld
OSMS_Carlsson's Avatar
Mercedes-Benz
Looks great!
Notice that you are in Toronto, certain tire size combinations don't exist here in the US, thanks for sharing the tires sizes but could you also share what Brand tire you used?
For those of you wanting to go up on the 4 matic and use the right aspect ratio, the sizes you used are about a 1/2" smaller in OD over the stock 19, so this might be a little forgiving with the concern for rubbing, but I think the need to lower the car will be a major must since the gap is already a strong complaint for most and with the shorter tires at 25.6 compared to the 19" factory @26.1, this is a great example for everyone to gather info.
Knowing the tire brand will be extremely helpful.
I was able to locate using a Pirelli combination with a 235/30-20 (OD 25.6) with a rear 285/25-20 (OD 25.6) which should be a precise match for the 4matic and 2wd W205's running a 8.5/10x20 combo.
Jim
Old 06-09-2015, 05:35 PM
angeloxnet's Avatar
I am running Nitto Invo tires
They are the only ones that make 275/25/20 rear
very pricey
Old 06-09-2015, 05:42 PM
Mercedes-Benz
very pricey
That will help for those wanting to upgrade to 20 inch!
Thanks for sharing!
Jim
Old 06-10-2015, 12:46 PM
angeloxnet's Avatar
my setup is technically not proper spec/diameter need to go up a profile
however it is within 3% difference
265's are prob better
Old 06-10-2015, 01:47 PM
vic viper's Avatar
S213
Actually 265´s are even smaller than 275
If you want to go dead on youll need 295/25, but I dont think they are available.
Quick Reply: My Mercedes C400 lowered on Vossen VFS1 airmatic
