Wiper blades for W205
Does the W205 take a different wiper blade from previous years? The manual's replacement procedure seems different. Is it a MB OEM only?
CliffordS
CliffordS
I had lots of chatter with the OEM blades so I rep!aced them with the Bosch Icon 22 OE blades. They are made to fit on on the Mercedes 300/400 wiper arms just like the OEM ones.I also applied Griots glass sealant and so far the new wipers have worked perfectly .
CliffordS
Do all three have the correct attachment and it's just a matter of getting the right length? Or is the "OE Wiper Blade" the one to pick (with the right length)?
I checked the Walmart.com web site and found 3 Bosch Icon wiper blades. Passenger's side (19 to 22 in; not labelled OE), Driver's side (17 to 26 in; also not labelled OE) and one that's just labelled "OE Wiper Blade"; ie not labelled as passenger or driver's side (20 to 24 in.)
The Bosch OE will not work. I went to buy some the other day and found out they do not work on the W205. Or at least i'll say that none of the connectors that came with it would mate to the W205 wiper arm. It's a little box connector. I'll take a photo later if I can. Seems like we're a the mercy of MB for now.
Yes the Bosch Icon 22 OE fit perfectly like originals
I replaced my wipers with these and they work and look perfect. No adaptor is used. They go on just like the originals.
gpouliniii (01-17-2021)
Mercedessophie, can you take a photo of the connector on the wiper? The OEs I bought at autozone would not physically fit on my c300 arm. Perhaps they changed the design since you got your c300? This is a little puzzling. Thanks!
Perfect fit wiper blades
Sorry for the delay. My 2015 C300 wiper arm does not look like that. It's supposed to rain this afternoon but when it stops i'll get a photo. Looks like they changed the design. There's a sliding mechanism at the top of the arm that gets pulled out and the wiper has what looks like a lego brick on it that connects to the arm. Totally different design.
I have posted pictures of the Bosch wiper on my C300. The connection is just like the original. Where is a picture of this other arm that they do not fit on? Why would you want the same bad Mercedes blade when there is a better and less expensive replacement? Wiper blades arms are pretty much universal.
2015 C63S E1 (sold 2012 C63 AMG Sedan (Premium & APX)) & 09 C300 Sport 4Matic
There are different wiper arms for this car. The style that I see on the new CLA will accept the Bosch aftermarket blade. The style on my car will not.
There is no aftermarket blade available for this new style arm.
This style requires you to push a small button on the plastic tip to release the blade and the Bosch can't possibly fit.
+1. It was probably a change they made in the MY and late year 2015 builds, which mine also falls into.
