Sat Nav question
Registered User
W205 C180 Diesel Auto
Sat Nav question
Hi all, I've just moved up the W205 from a W204 and have a query on sat nav's. I have a C180 diesel auto avant-garde which does not have sat have fitted. Nor do I seem to have the socket for the sim card in the arm rest. I rang the dealer and they suggested that there might be a connection in the glove box similar to the Becker system which was available for the W204.
Can anybody tell me if it is possible to retrofit a sat nav to the car and if so what are my options?.
Registered User
Don't I need to have the sat nav installed or does the DVD allow access to information without this. I was under the impression that the DVD was only to upgrade the system, I'm confused
Registered User
No Razzyh no SD card slot, just two USB ones. Checking the spec I did notice that the following codes are listed as being fitted.
270 GPS antenna and
522 Audio 20 navigation capable NTG5
I wonder if it might be wired for the SD slot and if a retrofit for the panel might be possible?. I also wondered if the Becker map pilot might be an option although I don't see the cradle in the glove compartment.
270 GPS antenna and
270 GPS antenna and
270 GPS antenna and
