Little choked up at pick up from 0 (at stop light sometimes)
Old 09-02-2015, 06:47 PM
Zenyatta's Avatar
2015 C300 4Matic Luxury
Enjoying my MY15 C300.
But sometimes it feels like it is applying brakes when I try to accelerate from a a stop. There is a little choked feeling, as if the car is holding me back.
Any idea what could be causing it? The car has so many self awareness features that I am hoping that it is one of those in action and not any real issue.
EDIT: Not sure if I am able to explain this right, but it also is similar to maybe slower gear changes maybe at those low speeds.
Old 09-02-2015, 09:00 PM
swagger_jacker's Avatar
'13 Infiniti G37
Sounds like you are talking about the shift between 2-3. There is threads around that talk about. I thought I read in one of them its a software update that is supposed to be out in a month or so, I could be wrong, I'm probably wrong. I mentioned it to my salesman when I picked up my ordered car and went on a test drive. He said it's normal, it was designed that way to sound like the AMG pop in the exhaust. I called BS and said that's the dumbest thing I have ever heard but what do I know. I guess we will see if they ever come out with something for it.
Old 09-03-2015, 12:20 AM
Zenyatta's Avatar
No, this happens at a much lower speed, just when you are pulling out of a parking lot kinds. Probably in the second gear then. It feels like the car is applying the brake for some reason, like you are driving with the parking brake on kind of a feeling. And suddenly everything gets better and you can freely accelerate if you just keep going.
Old 09-03-2015, 07:40 AM
MASSC450's Avatar
2016 C450 AMG
Sounds like turbo lag...I have it too.
Old 09-03-2015, 07:49 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Could it not be the auto hold?
Old 09-03-2015, 08:49 AM
c4004matic's Avatar
Received 1,067 Likes on 703 Posts
17 E43; 21 GLS580
+1 My guess too.
Old 09-03-2015, 09:00 AM
Zenyatta's Avatar
Originally Posted by c4004matic
+1 My guess too.
Is that the feature where you have to press the brake to display the "hold" sign. We hardly use that feature.
Also, this is not a very frequent thing but happened twice yesterday. Once was in the parking lot and next was after a stop light. The gear change felt little more prominent than usual (not just the 2 to 3)
Old 09-03-2015, 09:50 AM
c4004matic's Avatar
17 E43; 21 GLS580
If the road is not completely flat it will activate automatically for a few seconds so the car wont roll back. If you press the brake strongly it will stay on till you accelerate. The later is so you dont have to stay on the brake on red lights.
Old 09-03-2015, 10:59 AM
Zenyatta's Avatar
Thanks. Will keep an eye out on the road gradient when I feel it next time.
Old 09-03-2015, 04:07 PM
BlackjackM's Avatar
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
Did you hear a beep? If the collision prevention senses that you are about to hit the car in front of you it applies the brakes. It's happened to me a couple of times and surprised me.
Old 09-04-2015, 08:39 AM
Zenyatta's Avatar
As far as I can remember there was no beep
Old 09-05-2015, 07:51 AM
CrazySyd's Avatar
BMW E46
Software
Take your car in to the dealers, sounds like you need a software update, it fixed my gear issues anyway..
Old 09-08-2015, 01:28 PM
Zenyatta's Avatar
I found a display that pops up when I feel this "braking" feeling.
I am attaching a picture. It is that little "sensing an obstacle" (at least that is what I think it is) thing at the top. (P with radar waves hitting an obstacle)
When this pops up, it kind of restricts acceleration and feels heavy. But there is no immediate danger of any collision (but maybe the car knows better)
EDIT: Can someone confirm what it is.
Attached Thumbnails Little choked up at pick up from 0 (at stop light sometimes)-image1.jpeg
Old 09-08-2015, 02:05 PM
Steve71's Avatar
MY16 C300
That's the Parktronic icon. I've only seen it when I'm driving slowly, so I think it's saying Parktronic is active and there's a spot available. Manual makes this clear (NOT!!!)
Old 09-08-2015, 02:13 PM
Zenyatta's Avatar
Yes, it does happen only when I am driving slowly but I do get the feeling that the car is applying some braking pressure whenever the top one pops up.
If there is a parking spot available a "P" at the bottom with an arrow pops up.
I was not sure what the top one meant. This is the same display when I am pulling into a tight garage but it as some solid blocks on either side of P.
Could it be that it has sensed some cars around me but those are not close enough to warn me audibly? If someone can confirm that the car tends to brake if it senses something around it at slow speeds, then I will check this off as resolved.
Old 09-08-2015, 03:36 PM
Steve71's Avatar
MY16 C300
Correction: I was partially right. That's the Parktronic readiness indicator. From the Online instructions: "PARKTRONIC is operational if operational readiness indicator (the icon you highlighted) lights up".
Parktronic is the bar of amber and red lights that displays when you get close to objects.
Old 09-08-2015, 04:46 PM
Zenyatta's Avatar
That is interesting. Wonder why I felt a co-relation between that icon showing up and car feeling heavy/braking pressure.
Quick Reply: Little choked up at pick up from 0 (at stop light sometimes)
