My Screen stopped Working Today
Old 09-07-2015, 07:41 PM
Xzer0's Avatar
2015 C300 4Matic
My Screen stopped Working Today. I parked my car outside of my house last night and when I got into my car 12 hours later, my console screen did not work at all. I tried everything, but nothing worked. I can't see what i'm backing into because the screen is off. When I plug my iPhone through the USB port, it automatically plays songs. I can't drive like this. Do you guys think that the screen over heated from sitting under the sun on a hot day? What should I do?
Old 09-07-2015, 08:32 PM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
You should make an appointment at your MB Dealership and they'll take care of whatever happened.
Old 09-07-2015, 08:34 PM
rustycruiser's Avatar
2015 W205
To reset the system press and hold CD eject button for ~10 seconds
Samahy (10-04-2021)
Old 09-07-2015, 08:45 PM
Xzer0's Avatar
2015 C300 4Matic
What do you think happened?
Old 09-07-2015, 09:08 PM
rbrylaw's Avatar
Wouldn't have a clue. But doubt it's anything serious and that's what new car warranties are for. I will be curious to see if rustycruiser's suggestion restores your screen. I will want to remember that if it does.
Old 09-07-2015, 09:16 PM
2015 W205
One time half my screen was fubar, and that fixed it (I had written it down after seeing it posted a few months back)
Old 09-07-2015, 09:47 PM
rbrylaw's Avatar
Thanks!
Old 09-07-2015, 11:50 PM
cidtek's Avatar
C300 4Matic Tenorite Grey
While I feel bad for you having this annoyance, I do find it amusing that someone can't reverse a car without a camera.
The following 2 users liked this post by cidtek:
evanmarko (12-22-2021), Trappers101 (12-12-2019)
Old 09-08-2015, 01:52 PM
Xzer0's Avatar
2015 C300 4Matic
I tried the reset thing and it worked
The following 2 users liked this post by Xzer0:
Robert Longo (01-21-2022), Trappers101 (12-12-2019)
Old 09-08-2015, 01:53 PM
Xzer0's Avatar
2015 C300 4Matic
I couldn't reverse at all 'cause i'm so used to looking at it
Old 09-08-2015, 02:09 PM
rbrylaw's Avatar
That's great!
Fordgt40 (09-16-2018)
Old 12-12-2018, 05:20 PM
Rogue-CLK's Avatar
2016 C300 4Matic
thanks your a life saver, only works if audio work but the screen doesn’t. And no it won’t reset all music/saved files etc.
Old 12-13-2018, 03:04 PM
Cosworth2000's Avatar
2016 C450 AMG / C50 Lorinser
You should go to MB and get the latest software update.
Old 11-23-2019, 10:36 PM
Nimesh Menuka's Avatar
w205
in the new model w205 (2019~). You don't have a cd eject button. In this case, how to i reset the system when my screen goes blank?
Old 11-23-2019, 10:37 PM
w205
In the new model w205 (2019~). You don't have a cd eject button. In this case, how to i reset the system when my screen goes blank?
Old 11-24-2019, 07:36 AM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Is there a Power button for the screen? If so, try holding that down for up to 10 seconds.
Old 11-24-2019, 05:41 PM
Abohunu's Avatar
W205 C250 2016
I don't know if happened the same to you but in my case I had some white strips in the screen.I noticed in each failure Bluetooth was on and changing my phone with a usb cable. The failure happened in the exact moment I unplugged the usb cable.
Since I stopped charging via USB, everything is back to normal.
Old 12-11-2019, 11:26 PM
w205
It does reset the Command system. The radio stops working, and restarts. The screen also reboots when its on. But when the screen goes blank, which occasionally happens that been the problem, then holding that button would restart the command system including radio, but the screen does not turn on. But if the car is parked overnight, the next day or so, the screen will turn on when I turn on the car.
So basically the screen turns off and again back on whenever it wants. Even goes blank and back on while driving (not as soon as it turns off). Nothing happens to any other system such as radio or reserve aids. But doing anything wouldn’t turn the screen on unless it wants to turn itself back on.
I even did a software reset on the command system, when the screen was on.
Just one point I noticed, when the screen goes blank, the brightness of the LCD instrument cluster increases even at night, and when the screen is turned back on, then the brightness of the instrument cluster gradually goes down with the command screen itself, which also turns on with high brightness after a nap.
Any support?
Old 07-30-2020, 05:24 PM
MassE55's Avatar
2001 e55 AMG
XPipe Today
Finally had some time to get a new X Pipe installed. Now the exhaust system is complete!! Kleeman headers, x pipe, de-catted and no resonator with stock muffler. Sounds and feels great
Old 07-30-2020, 05:29 PM
MassE55's Avatar
2001 e55 AMG
Sorry guys posted in wrong forum....carry on 😜
matt.jessop (07-31-2020)
Old 10-25-2020, 07:26 PM
Lisa Gauthier's Avatar
2014 S550
So, my screen locked up, on a road trip, nothing. I frantically began searching and can across your suggestion to hold the eject button down..... it worked!!!!
Old 09-04-2023, 10:48 AM
dadoman's Avatar
c-class C200d w205
i'm a new member. did you find a solution?
Old 09-04-2023, 10:50 AM
dadoman's Avatar
c-class C200d w205
Any support?
do you have a map on a sd card? believe it or not, that was the solution to my problem. I ejected the SD card, and it never happened again
Quick Reply: My Screen stopped Working Today
