w205 ac/climate control
I bought a new c 300 recently and i simply can't figure out the difference between climate control and having the AC turned on .
1. without turning the AC toggle on , i can adjust the temperature from cold to hot air blow. what is the point of the AC button then ? also fan stops working if i turn off climate control . what does that mean ?
2. the fan takes like a minute before it starts blowing air after i start the car. Even though i set it to blow straight to my face it starts blowing on my legs first and then after a minute adjusts to my setting . Is this normal ?
2015 C220 AMG Line Bluetech.
Climate Control means you can set the desired temperature, and the car will automatically use its heating/cooling (A/C) systems to achieve that temperature. So the A/C itself is one component part. Cars without Climate may still have A/C but you manage temperature manually (by turning off when you get too hot/cold!)
You can still use Climate with the A/C switched off (ie - my wife gets sinus pain in cars with A/C running) - but the best it can do is circulate fresh air around.
Hope this helps.
Hope this helps.
The A/C also takes moisture out of the inside air and reduces condensation on the glass. In cooler weather, and after the car is warm, I will sometimes turn it off for a while to help improve fuel economy a bit.
Something that I have noticed though is that if the air isnt really blowing out because the system does not sense it needs to due to temperature or whatever, I hear the mechanisms moving, it sounds like its coming from the far left and far right circular vents, especially hear it when auto-start stop is active when the car is stopped, and the temperature is similar to what i have it set to.
Well I should probably backtrack a bit and say that there may be some kind of function to delay the fans or whatever on a cold engine but mine does it when the engine is warm also. In addition to that i've had times where I start the car on a cold morning and it immediately begins blowing cold air, so I know I have some sort of problem because the behavior is so erratic.
Mercedes C W205, Previous: Mercedes ML W164
Very strange behaviour of the dealership. Especially Mercedes dealership.
At number 2: there is an option in the menu for climate control where you can set the air flow type. Watch my video for fun Hope you guys like it
2015 C300 4MATIC
Related question ... windshield defrost. Is there a way to adjust the fan speed and temperature? When I turn it on -- works great -- but the fan is very high and dont want to drive like this. The alternative is to do a quick defog; turn off; wait for it to fog again; turn it on; repeat.
A/c won’t come on
Hello, I’m facing this problem on c63 w205 the AC won’t come on after I stop the defrost button. It does come on if I push the button alone but I remember it used come on after I do the defrost.
I usually leave the ac off when I drive so that’s what I notice that didn’t come on after defrost.
does anyone experience that?
1 Post
2021 C300 AMG Line Sports Coupe
Can anybody answer why MB discontinued the M264 engine after 3 years in circulation. I have a 2021 C300 AMG line sport coupe which is the last years for the M264. I’m aware of the problems with the M274 MB engine. Is this the same problem, cracked piston? Damm I hope not.
Last edited by mr e350; 05-01-2023 at 02:48 PM. Reason: I apologize for being in the wrong thread
2016 C450
