Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-08-2008, 01:34 PM   #1
Drives: C32 2002
Battery question
Hi guys,
I have a 2002 c32 and the battery in it was never replaced, now if I leave the car for 3-4 days without using it, I have to boost it before it will start up on me. My question is, do I need a new battery ? Also, what is a good battery to buy or do I need to get one from the stealership ?
D
To remove this ad, register today or login if you already are registered!
Avi02C32 is offline   Reply With Quote
Old 03-08-2008, 01:48 PM   #2
raymond g-'s Avatar
Drives: 99 E320
too simplistic. in order to ascertain the health of a battery, one really must
1) check specific gravity of electrolyte, 2) ensure proper fluid level, 3) verify
cells aren't shorted, 4) check and/or charge battery, 5) check battery voltage
under load, 6) perform #1 again
then....one can better advise as to whether a new battery is needed. it may,
for example, simply need fluid topped and recharged. if so, that costs pennies.
if it had been allowed to deteriorate over the months/years to where the plates
have sulfated and shorted out adjacent cells, that's almost irreversable and a
for my 210 i simply went to Autozone and bought a similarly sized battery (with
near identical cold cranking amperage) and paid 1/2 what one would cost from
MB / free roadside assistance. for a battery 6 yrs old, generally, it's about
time to replace but no need if it's one of the simplier above fixes
__________________
raymond-
47º34'N 122º18'W
raymond g- is offline   Reply With Quote
Old 03-08-2008, 01:48 PM   #3
whoover's Avatar
Drives: '06 S65, '06 C55
Quote:
Originally Posted by Avi02C32 View Post
Hi guys,
D
If the battery is 6 years old, it's time to replace it. But you may also have a bad seat or door control module, which are notorious for causing battery drains. But I'd replace the battery and see if the problem goes away before looking for a drain. (The way to see if you have a drain is to wait for 30 minutes or so after the car has been switched off an check current flow at the battery with an ammeter. If it's around 1 amp, you have a bad module that's preventing the CAN-B network from sleeping.)
You can get cheaper batteries, but in my experience nothing lasts like the OEM battery. For another 6 years, I find the extra bucks worth it to buy the replacement at the dealer. If you don't make sure it has the same rating, group and venting arrangement as the OEM battery.
whoover is offline   Reply With Quote
Old 03-08-2008, 02:21 PM   #4
Drives: 1993 190E 2.6
I don't have a C32, but the person who had my car before me put an MB Battery in it back in 2001. I just replaced it the end of last year. That battery lasted 6 years. Whereas the new one I just purchased for much cheaper, will only last me ~2 years. I don't plan on having this car for more then that so it didn't make a difference to me.
Even if it as simple as recharging it, I would recommend getting a new one anyway. Its about time. The last thing you want to do is recharge your batter then in 3 months it dies from old age and you are screwed. I would change it at your earliest financial convenience.
__________________
Sport Suspension Tuned for Drifting8K HIDLSDK&N
Custom Black Badges & GrillEclipse/JL Audio1 of 1,200 Made
I don't have to remember my accomplishments
to know that they exist.
PhilipM1 is offline   Reply With Quote
Old 03-08-2008, 02:24 PM   #5
SPONSOR
loungn14's Avatar
Drives: Eurocharged Performance E55 Beast
pages/Eurocharged-Performance/248481410297 eurocharged
Just replace it yourself.....only about 90 bucks from an auto shop, and an easy install in the c32
loungn14 is offline   Reply With Quote
Old 03-08-2008, 02:26 PM   #6
t76turbo's Avatar
Drives: 05 clk 55 conv., 03 E500, 01 E55, 03 F350, FJR1300....
I just went through the same problem with the car hybernating for winter. I would charge the battery, then 3 days later I wouldn't be able to start the engine. Repeated that cycle for about 2 months thinking something is draining the battery. I went as far as placing a rag over the light/rain sensor thinking that everytime I turned on the garage lights my car would energize some mopdule and drain the battery. Finally I replaced the origional battery with a new OEM battery and all problems went away. BTW I had an "electrical consumers switched off" warning that came on every now and then on my w211, since the new batt. no more warning and it starts every moning.
__________________
2003 E500 20's w 285, fabspeed exhaust, K&N's, custom stereo w 8" in dash screen, suade headliner and a few other mods.
2005 clk500 conv. lowered, 19"sl63 wheels, exhaust
2001 E55 with crossover exhaust mod, 19"
2003 F-350 King Ranch on 38.5 with 12" lift
1995 Stang, 331 strocker, DFI, T-76 turbo...
FJR1300, Muzzy single pipe, PCM, Airbox mod
t76turbo is offline   Reply With Quote
Old 03-08-2008, 04:15 PM   #7
TemjinX2's Avatar
Drives: 03 g35 coupe...........02 c32 Sold
there all the same. Even my cheap $40 walmart battery lasted 4yrs in my civic before i sold it. Just buy a cheap one at a auto store. Its usually around $89. Since your in canada, i would get the one with the higher cold cranking amps.
if you want the best, get a optima battery. its around the same price as a oem battery.
TemjinX2 is offline   Reply With Quote
Old 03-09-2008, 12:15 AM   #8
timberman's Avatar
Drives: silver 2002 c32 amg
My battery died 2 days ago,
It had turned over slow a couple of times previously and I got an error message about light sensor not working but other than that there was hardly any warning , I climbed in turned the key and nothing,
luckily I was at home at the time and not stranded in the middle of nowhere.
I got a new one from the dealer and swapped it myself, took about 5 minutes
mines also 6 years old and I believe anything over 5 years and your doing well
__________________
C:\Documents and Settings\peter\My Documents\My Pictures\fighting torque\l;rkger;.jpg
LET 181 PULLEY,
LET PHENOLIC SPACERS
EVOSPORT HEADERS
H&R SPRINGS
H&R SWAY BARS
C55 WHEEL WELL
C55 QUAD EXHAUST
SPRINTBOOSTER
MP DESIGN CARBON FIBRE STEERING WHEEL
AMG FLAT HOOD EMBLEM
AFTERMARKET GRILL
TO DO
INTAKE
ECU REMAP
WHEELS?
timberman is offline   Reply With Quote
Old 03-09-2008, 06:29 PM   #9
bud4ya's Avatar
Drives: 2003 C32 AMG, 2003 E39 M5
AnY battery that is that old should just be replaced. Not worth being stranded over $100.00.
bud4ya is offline   Reply With Quote
Old 03-12-2008, 02:30 PM   #10
c32used's Avatar
Drives: LET C32 2002
Send a message via Yahoo to c32used
Hi guys,
D
First disconnect your under seat control modules (3 plugs each side) then try starting your car the next day if it starts fine then its your seat controller...I wouldn't replace a battery unless it needs to be new or I wanted a battery with better performance and less weight. Let us know if this works...
c32used is offline   Reply With Quote
Old 03-13-2008, 10:53 PM   #11
dkflipse's Avatar
Drives: C32 AMG
Quote:
Agreed. I paid the $100 at Sears. Car died 2 days alter and I had to pay $600 or so for the dealer to fix the seat cotrol module. But now I know I won't need a new battery for another 4-5 years, and won't get stranded cuz of it.
__________________
Renntech Stage I, Y-Splitter, H&R Springs, 352 RWHP/361RWTQ
http://forums.mbworld.org/forums/sho...69#post2565669
dkflipse is offline   Reply With Quote
Old 03-13-2008, 11:50 PM   #12
c32used's Avatar
Quote:
Wow $600.00! There is a member of this forum that bought seat modules from another C Class on Ebay for $100 shipped and did the work himself.
Thank God I still have warranty! They repaired my seat control modules recently and now gonna fix the seat heater (Driver's side lower seat)
__________________
LET-Eurocharged the works
Ventus Evo/19" Bremmas
Newbie search http://mbworld.org/forums/showthread.php?t=201140
Kenwood DNX7100 http://mbworld.org/forums/showthread.php?t=233993
Buyer/Seller ratings thread: http://www.mbworld.org/forums/c32-am...ng-thread.html
Old 03-14-2008, 12:07 AM   #13
TemjinX2's Avatar
your lucky the dealer tried to charge me $1k for both modules installed. I got really pissed when it only took me 30min to install the modules.
$400 for both modules + $600 for labor.
$600 for 30min of work. I think i went into the wrong profession.
Anyways, i saved $900.00 i'm happy.
Old 03-14-2008, 12:25 AM   #14
c32used's Avatar
Talking
$1k
That's why everyone refers to them as the Stealership...
__________________
Old 03-14-2008, 03:53 AM   #15
TemjinX2's Avatar
They should only charge $100 for labor. But 600% markup is definately bending you over. I'm glad i'm a diy'er. I think you have to be, at the rate these dealerships charge.
Tags
2002, amg, battery, c32, c55, factory, location, mercedes, oe, oem
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
