Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-15-2008, 08:20 PM   #1
Fifth Ring's Avatar
Drives: C32 AMG
It was the s/c intercooler coolant pump. Fixed now.
I swapped the original pump for the Ford Lightning / Bosch pump. Install was pretty easy. It's still a pretty tight area to work in - especially getting the hoses off. No more power drop-offs. I hooked the old pump up to a DC 9V source and it was free spinning but very slow.
I did not come away with great confidence that the new pump will hold up. It's a less robust pump (appearance and hardware) than the original pump. Old pump had a metal housing while the Lightning pump is plastic. Original pump had a drain tube, I suspect to protect the pump if the impeller leaks coolant into the electric motor. Lightning pump has no drain. The new pump impeller cap is held on with cheap philips-head screws that were hard to remove without stripping the heads. I got them all back in, but partially stripped the head on each one.
If I need to go with the Johnson pump, at least I know how to do it.
To remove this ad, register today or login if you already are registered!
__________________
2002 C32 AMG [SOLD] -> 2009 G37C
+ 2008 MB GL320 CDI (family locomotive)
+ 1988 Porsche 944 (keeps the C32 off the track)
Fifth Ring is offline   Reply With Quote
Old 03-18-2008, 05:06 PM   #2
c32used's Avatar
Drives: LET C32 2002
Send a message via Yahoo to c32used
c32used is offline   Reply With Quote
Old 03-18-2008, 05:35 PM   #3
SPONSOR
loungn14's Avatar
Drives: Eurocharged Performance E55 Beast
pages/Eurocharged-Performance/248481410297 eurocharged
nice job.....just make sure you blead the system well and good to go!
loungn14 is offline   Reply With Quote
Old 03-18-2008, 06:54 PM   #4
I had the ford bosch pump on my c32 for over 2 years...no issues ...still works
but I should replace for the cm30 which in my opinion works a bit harder based on touch and feel on my 2 cars.
__________________
2002 C32 AMG (Stage 1) Gone
2003 E55 AMG (Stage 1) Gone
2012 E550 Coupe/ Stage 1 OE tuning
- W212 E63 18" rims 9" and 9.5"
2008 Toyota Land Cruiser 4x4 (200 Series)
TopGun32 is offline   Reply With Quote
Old 03-18-2008, 07:34 PM   #5
Drives: 2002 c32
We finally popped your cherry
__________________
Bif Powell
2002 C32: C55 rear deck spoiler - Euroteck Carbon Fiber Lip - AMG F1 Medical Car Steering Wheel - Stop-tech Steel-braided brake lines
2000 S4 Stage II: MTM Chip - Neuspeed Cat-back Exhaust
Bif powell is offline   Reply With Quote
Old 03-18-2008, 08:52 PM   #6
SPONSOR
loungn14's Avatar
Quote:
god thats funny....
Tags
99, 9v, amg, antifreeze, bosch, coolant, cooling, e55, ford, hdd, intercooler, leaking, lightning, pump, sc, slow, spining
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
