Sign in using an external account
| C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#26 | |||
MBworld Guru
Drives: white and whiter
#27 | |
MBworld Guru
Quote:
I've been corrected in more times you can think of over the period of 6 years owning this car and I've gladly learned from it. and regarding spacers I'm sure you are against it too right? |
#28 | |
MBworld Guru
Quote:
#29 | |
Quote:
I'm asian so this a simple but lame example: Imagine the equal signs are 'chopsticks' and 'xxx' are your hands. Now imagine that xxx1 is resting on a table with the chopstick underneath while the remainder is dangling over the edge. Its alot easier to break the first chopstick (which your hand is further apart). xxx1------xxx2 ========= xxx1--xxx2 ========= Throw in the mass of wheel/tire and the force of the suspension travel moving in 3 axis and gravity, that extra 10mm exponentially does make a difference. I have no doubt that the quality of materials are probably good, otherwise your wheels would have fallen off long ago, but I sincerely believe it adds alot of stress to alot of components besides the bolts hubs and suspension components. Last edited by crazeazn; 04-11-2008 at 04:22 AM. |
#30 | |
MBworld Guru
Quote:
OP: is it going to rain today? 1st guy: hm...look at the clouds...it'll rain 2nd guy: yea, I agree...look at the clouds it'll rain 3rd guy: i heard it's going to rain too 4th guy: i read the weather...it won't rain it's just cloudy 1st, 2nd, 3rd guys: once again the smartass said it won't rain...damn it...we feel bad because we didn't read the weather, but lets gang up on him anyway. |
#31 | |
MBworld Guru
Quote:
I'm not saying that the 5mm spacer actually made the hub on the wheel thicker for the ET35 wheel than then ET30 wheel as you described in your example. I agree of course if you extend that hub too far with the spacers then you are putting all the stress onto the bolts and the hub. BUT if you have a wheel with the same overly aggressive offset without the use of spacer you are still putting all the stress onto the bolts. here's what I meant to say with a quick drawing Last edited by FrankW; 04-11-2008 at 05:20 AM. |
#32 |
nice diagram frank! i see your point AND you are correct about if a wheel with has an aggressive offset, you are still putting all the excess stress onto the bolts. But adding a spacer/adaptor is just one more piece in the system which makes it worse....
#33 |
I don't want to say the argument is pointless but if we're going to get down into physics and all of the engineering jargon, don't you all think BBS, H&R, HRE, and the likes have thought about all of this before they released any of their products to the consumers?
Being as large as they are and the litigious country we live in, I doubt they'd be selling their wheels as such if it was indeed a huge problem. The debate is good information but I think it is being overanalyzed, by just a tiny bit.
__________________
![]() '05 Mercedes-Benz C55 AMG Car: Alabaster White | Black Leather w/Birdseye Maple Trim | Lighting Package | NAV | Steel Carter Plate (Option 481) Mods: KW V2 Coilovers | 19x8.5F/19x9.5R BBS LM | Toyo T1R Tires (235/35/19F 265/30/19R) | Euroteck Carbon Fiber Front Lip | Evosport Painted Sidemarkers | OEM Flat Hood Emblem | Fuel Content Mod | Netherlands Setting Mod |
#34 | |
Quote:
#35 |
Drives: 02 CLK 55 AMG Cabrio, 07 ML63 AMG
Does anyone know if running the incorrect tire size in the rear will cause the rear differential to make noises?
Here's my situation: Running Axis Milano on a CLK 430 - 19 x 8.5 front and 19 x 9.5 Rears with 35 mm offsets on all 4 wheels with Kumho Ecsta SPTs: - Front 235 35 19 which is the correct size - no issues with them installed. - Rear 245 35 19 which isn't the ideal size of 265 30 19. - With the 245 35 19s installed, I'm hearing a clicking noise when driving slowly. I don't know if it's a spacer issue since the rims in the rear are 35mm offset and the AMG wheels that came with the car were 30MM offset. If it's a spacer issue, do I need a 5MM Hubcentric one or since it's only 5mm, don't bother with hub centric? I took one of the rear wheels off and did not notice any severe rubbing. So, I've narrowed it down to either 5mm spacers or incorrect rear tires. Anyone have any thoughts on this? Is the 265 30 19 that big of a difference that 245 35 19s would cause differential issues??? The wheels look great on the car, but I'm afraid to drive it right now. By the way, some Kmho Ecsta owners have reported that running 265 30 19 have sight rubbing issues due to the roundness of the Kumhos on MBs. Last edited by newguy2008; 04-23-2008 at 02:38 AM. |
#36 |
Drives: C63
The clicking in the rear at slow speed or at any speed could be your bolts hitting the retention springs for the parking brakes. Did you swap out with longer bolts to run the 5mm spacers?
__________________
Mercedes Benz C63 AMG
#37 |
That kind of makes sense as my first thought was that it sounded like it was coming from my parking brake. I thought that it was sticking so I engaged and disengaged it several times.
I'm not running any spacers at all yet. The bolts looked fairly short as it was. This would also explain why some of the bolts that came with the rims were slightly smaller (2-3 mm?) than the others. I'll check this out tomorrow night. The guy that I purchased the rims from didn't mention this at all. Thanks. Last edited by newguy2008; 04-23-2008 at 01:21 PM. |
#38 |
Drives: C32 AMG
Dude! You need to get this fixed ASAP. I am 99.9% sure it is the bolts rubbing. I had the same problem and ignored it for a few weeks-since it seemed to go away at high speeds. You are running a very big risk of damage/death. Look at the link below below.
http://s213.photobucket.com/albums/c...chmentaspx.jpg This happened going 5MPH - thank god. All bolts snapped off!!
__________________
Renntech Stage I, Y-Splitter, H&R Springs, 352 RWHP/361RWTQ http://forums.mbworld.org/forums/sho...69#post2565669
#39 | |
That's scarry!
Good thing that I took the bus to work today - lol - 1st time in a long time. It was too late in the evening to continue messing around with the wheels. Tonight though. Quote:
#40 |
Thanks for the help guys/gals!
It was the locking wheel lug. 2 were shorter at 0.875 of an inch which are supposed to be for the rear and the longer ones at 1.125 inches are for the fronts. I didn't know that there was a difference. But the noise is all gone. This site is awesome! I'll post pics later. I must head out to burn some expensive fuel now. Thanks again! |
#41 |
#42 | |
MBworld Guru
Quote:
#43 |
#44 |
H R Wheel Spacer - which bolts do I need?
I am considering purchasing 10mm Front spacers (20556659) and 12mm Rear spacers (2455665) by H&R for a 2005 C55 AMG with stock wheels and tire sizes.
Can anyone provide the correct part number or specifications (taper or round bolt head and shaft length for the required 'longer wheel bolts" ? As well, does anyone have a preferred vendor for their 1. Tune up (a/b service) parts 2. Performance modification New here, so HELLO to all ! |
| Tags |
| 18, 18x85, 24045, 7mm, amg, bad, c55, et35, fenders, idea, mercedes, put, size, spacer, spacers, tire, wheel, wider |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
