C55 Catalytic Converters
I just borescoped my four cats to look for restrictions. What do you guys think?
They look clear to me.
I've included a couple of photos from a cat article I wrote. This first one has a gazillion miles, and it's partially clogged.
This second cat is new.
Your's looks a lot like the new one. It's been my experience that when MB cats go bad, it's because the welds that hold the ceramic substrate in place fail. The ceramic core then rattles around until it breaks up into small enough chunks to clog the cat itself, or the muffler. That's the secondary reason why cats with a metal substrate are so much better - the welds hold up. The primary reason is they flow better.
2005 Brabus C55
bored ... that's gross ...
You have four cats ... that's way too many.
Seriously ... https://mbworld.org/forums/showthrea...170&highlight=
My cats collapsed & created a surprising amount of back pressure. The new cats are purrrrrrring like new.
Last edited by Brabus C55; 04-19-2008 at 01:26 AM. Reason: i cn't f'ing tyyype .... wwhyyyy ?!!/?1?1?
Actually, Brabus 55 made me probe the cats on a MB cat campaign.
I was kind of bored!! I went thru the exhaust tips for the back-side of the secondary cats. I then went thru the O2 sensor to look at the front of the secondary cats and the back-side of the primary cats. I did not look at the front of the primary, which could be done thru the other O2 sensors.
Resonator Pic attached
