Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-08-2009, 11:14 PM   #26
c32used's Avatar
Drives: LET C32 2002
Send a message via Yahoo to c32used
nice!
To remove this ad, register today or login if you already are registered!
__________________
LET-Eurocharged the works
Ventus Evo/19" Bremmas
Newbie search http://mbworld.org/forums/c32-amg-c55-amg-w203/201140-one-stop-search-newbies-start-here.html
Kenwood DNX7100 http://mbworld.org/forums/c32-amg-c55-amg-w203/233993-kenwood-mobile-entertainment-installed-my-c32.html
Buyer/Seller ratings thread: http://www.mbworld.org/forums/c32-am...ng-thread.html
LEARN TO PLAY MYSPACE MOBSTERS BETTER PM ME
c32used is offline   Reply With Quote
Old 03-08-2009, 11:23 PM   #27
alboogiee's Avatar
Drives: 2006 C55 AMG
alboogiee
Nice write up... but what's up with your bumper fitment?
__________________
alboogiee is offline   Reply With Quote
Old 03-09-2009, 12:27 AM   #28
TemjinX2's Avatar
Drives: 03 g35 coupe...........02 c32 Sold
i didnt put back the side rails out of lazyness. i'll probably put it back later.
TemjinX2 is offline   Reply With Quote
Old 04-30-2009, 01:38 AM   #29
Drives: W210
Send a message via MSN to B189s
Quote:
Originally Posted by TemjinX2 View Post
Here's my update 5-27-08
i decided to removed the lower part of the head light to make it easier to work with.
It seems to be held to the head light housing at 3 ball joint locations. They can be pulled out with some light amount of force.
Pic of the lower head light with the mounting holes.
Drilling the mounting hole location is probably the most important part of the whole project. Your drill location will determine how much rotational adjustment you have to do later. So take your time
i discovered having the screws faced inward was better. This way i can make any adjustments by using a philips screw driver
pic of it lit up
here's a wall shot. As you can see i fixed the rotational angle.
The camera was set on auto with no flash. The beam is a lot more blue in real life.
Right now i jb welded the screws today. I ordered some oem nissan head light sealant, to seal up the head lights. Hopefully i can have them mounted later this weekend
That's a clean and sharp cut off. I guess that's the difference between OEM projectors and aftermarket Chinese made projectors. I'm prety happy with my cut offs and output tho, I mean compared to my clears + HID combo before.
BTW, you should've bought the OEM BIX looking DEPO headlights. What you have are the E looking ones. All they have now locally here are the E looking ones too and that's when I decided to install my projectors in my clears since I knew it would've looked the same after the projectors were installed.
B189s is offline   Reply With Quote
Old 04-30-2009, 02:48 AM   #30
TemjinX2's Avatar
i probably couldnt fit the tsx hid projectors in the depo ones. The reason i choose the eagle is because they were cheaper and there was lot of room in the back to basically fit almost any hid projector. The tsx projector was significanty wider then the projectors that were in there.
I kinda wanted mine to look different from everyone elses, so thats why i added the e46 shrouds.
You can really tell just from pics, you gotta put your car next to like a s2000 or a ls430. You'll notice the hid projector beam is a lot wider and brighter then your halogens. But the cut of on your halogens is really good, for a halogen projector.
Old 09-24-2009, 06:57 AM   #31
maverik259's Avatar
Drives: 2005 C230K SS black/black
Damian Roudebush
whats up with the scraps of light coming off the top of your final cutoff beam? wasn't there in your other pics!
__________________
Kenwood 1000w Amp | 2 10" JL | excelon 6960 in-dash l #303 white star hood badge l CL style grill l OEM bix+6K Ultinon l SB l 19" TSW Snetterton l LED evrything l chrome AMG door locks l smoke side marks l AMG spoiler l cf front lip l Dig HVAC l Birdseye trim l HID 6k fogs l K&N | Eibach rear sway | gold calipers | R1 x-drill
maverik259 is offline   Reply With Quote
Old 09-24-2009, 06:42 PM   #32
TemjinX2's Avatar
Quote:
there's a slight flare on a lot of tsx projectors because the shield itself is reflective which is gives off a slight flare. Its more pronouced in that pic because of the camera settings and the fact i'm using cheap chinese bulbs which aren't built to oem spec.
Oem bulb would reduce or get rid of the flare. it doesnt effect light output or blind drivers so its not really a big deal.
Old 09-25-2009, 02:24 PM   #33
maverik259's Avatar
Damian Roudebush
aha
__________________
Old 11-06-2009, 09:48 PM   #34
Outkasted24's Avatar
Drives: '05 C230 Kompressor SS
How exactly did you Shave The Glare lines off of the Lenses and still get them so clear?
Outkasted24 is offline   Reply With Quote
Old 11-06-2009, 09:58 PM   #35
TemjinX2's Avatar
Quote:
you can just sand off the lines...similar to how you restore head light with the yellow on them. its more clear but not as clear as a head light that came clear in the first place.
i'm working on a another retro soon with completely clear head light covers.
Old 11-24-2009, 10:03 PM   #36
TemjinX2's Avatar
i started a new thread for my s2k projector retrofit project.
http://www.mbworld.org/forums/c32-am...-retrofit.html
Old 11-26-2009, 09:54 AM   #37
Looks Great!! , But could you have just done the Color Mod to the TSX's and saved money and time?
About the aftermarket lenses with the lines.......
Could you have just taken the OEM Benz Lenses off of the Stock housings and fit them on the aftermarket retro'd housings? ..... Or do they not line up properly?
Old 11-26-2009, 04:53 PM   #38
TemjinX2's Avatar
well the tsx's and s2k's are distinctly different. The tsx has the widest single xenon beam, but the s2k almost has as wide of a beam but has more intensity and color.
Its just like all v6's are different, you can't put a e46 m3 head and put it onto a c32 and expect it to rev to 8k. The reflector bowl of the projector has more of impact on beam width and intensity.
After far as the head light covers, the oem benz covers aren't completely clear either. They come with the vertical glare lines thats designed to reduce glare and kill the hid flicker color.
Old 03-02-2010, 06:12 AM   #39
TemjinX2's Avatar
For future use. Here's the link for the nissan head light sealant. Its $20 plus shipping.
http://www.mynismo.com/products/?id=5577
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
2006, adjust, align, bright, carputer, depo, grill, integra, mounting, projector, replica, retrofit, tsx, w203, wallshot
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
