Sign in using an external account
| C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: C32 AMG
Power Steering sound/issue/leak? HELP needed thanks!
__________________
![]() mods: Green Filter, H&R Springs, 8000K Bi-Xenon, Clear Blinkers, Black Side Marker, Resonator Delete, Custom Subs and Amp, 15% Tint, 19" Brabus Mono S, Flat hood AMG badge, BRABUS Shifter, BRABUS Steering wheel, Carbon Fiber Trunk Lip Spoiler, EVOSPORT pulley kit, LET headers, NKG Sparks, Custom ECU. Selling: BRABUS Steering wheel |
#2 | |
Drives: Not an AMG :(
Quote:
The noise is probably due to low power steering fluid (PSF) levels. Did you check the PSF level in your car? That's the first step. Several possibilities come to mind: A) Many people (not just our cars) experience a 'groaning' noise when initially steering in the cold because the extreme cold decreases the volume of the PSF. If your PSF levels are borderline to begin with, then the extreme cold will decrease it past that threshold level. B) The noise could be due to the power steering pump going bad. Perhaps there's a bad bearing. C) (Most obvious) - you have a PSF leak. You alluded to an oil spill around the 'oil pan'. Do you mean the splash shield? How much PSF? (again, try to make a correlation with your current PS fluid levels). Do you see oil dripping from the power steering hoses? - You need to check these. Do you see oil dripping from the fluid reservoir? - This may also explain the noise if air is allowed into the system. D) Is your polyV belt in good shape? Maybe it's worn (glazed) and there isn't good contact between the pulley and the belt - that may lead to a screeching noise. |
#3 |
I have the same issue too..
its a rubber hose with a metal crimp leaking the fluid. Best way to inspect is through the bottom. Lift the car or use a car jack. Remove the plastic cover. the fluid is all over my plastic bottom cover and around the power steering pump area. add more PS fluid for now.. but you will have to find how to stop the leak eventually. I used to have the noise, but I have been adding fluid every 2 or 3 months.
__________________
2002 C32 AMG (Stage 1) Gone 2003 E55 AMG (Stage 1) Gone 2012 E550 Coupe/ Stage 1 OE tuning - W212 E63 18" rims 9" and 9.5" 2008 Toyota Land Cruiser 4x4 (200 Series)
#4 |
Drives: C32 AMG
thanks all, i will be bringing the car to the shop monday to get it checked out!
Still kind of worried, i will first check the PSL today, btw where can i ge some fulid for the car? Thanks!
__________________
#5 |
Drives: 2002 Blue C32
I had the same issue....All I have to say is THANK GOD FOR MY EXTENDED WARRANTY!!!
First it started with the noise then came the smell with smoke when I turned lock to lock. It got worse when the car was under boost. Anyway, the dealership replaced my rack because all the bushings were toast. Anything rubber under thecar had to be replaced due to fluid contamination including the motor mounts, tranny mount, and all bushings. The pump had to be replaced also because of metal shaving and debris passing through it. The total bill was $3900!!!! It cost me nothin!!!!!
__________________
2002 C32 ...LET headers, LET heat exchanger, LET IC pump, LET 181mm pulley, and K&N filters. 347rwhp / 352 tq |
| Tags |
| amg, c32, cold, e55, extreme, fluid, hoses, leak, leaking, power, psf, sound, steering, tranny, type |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
