Sign in using an external account
| C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 03 E55
Quick supercharger question...
#2 |
Drives: C32 AMG
just with any forced induction components that went through high speeds to force air; it is the bearings that take most punishment
![]() the s/c on the c32 runs anywhere from 13000 to 18000 rpms depending on boost levels mine has been going w/o any probs, bought the car stock at 30000 mi, now at 65000 miles ![]() mine runs on 17 psi with aftermarket pulley which comes with replacement bearings since 50000 miles, however at 50k miles, the orig. bearings are still fine, the new bearings are installed just for peace of mind the other prob you might encounter with c32 s/c are the electro clutch that controls the kompressor engagement, i haven;t had this probs yet (knock on wood) but search the forums, this topic had been widely discussed by members good luck
__________________
AMG meets the horizon
#3 |
Drives: 03 g35 coupe...........02 c32 Sold
i'm at 84k with supercharger still going strong. My bosch intercooler pump was on its way out...other then that no mechanical problems. unlikethe electronics in the car the supercharger is actually japanese..from a very dependable company. I wish they used japanese electronics too and it would've been perfect.
__________________
2002 Mercedes c32 amg S2k projector retrofit http://www.mbworld.org/forums/c32-am...-retrofit.html My carputer http://forums.mbworld.org/forums/sho...d.php?t=237456 TemjinX2's rides http://forums.mbworld.org/forums/sho...=1#post3053382 FREE C32 BLOCK/ PART OUThttp://mbworld.org/forums/engine-per...ml#post5433265 |
#4 |
Mine gave up around 70K. But...the supercharger itself is in top notch shape.
__________________
![]() E55 - E63 conversion, CF Spoiler, CF Diffuser, CF Lip, Black OEM grille, LED City Lights, FlooredFab LT's, Kleemann 168, EC Heat Exchanger, EC Jerry Tune, K&N drop ins, 19" Black star AMG reps, lowering links up front. First time at the track (against a ZL585 Camaro): http://youtu.be/TKWZe2fRiAs MBWGOC Member # 108 |
| Tags |
| c32, high, smoke, speed, white |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
