How to reset service light after oil change?
c55 amg
Is how everyone does it? I found the below info at http://www.synthetic-direct.ca/techn...t_mercedes.htm
C230 CLK35O R350 ML350
C280 CLK500 R500 ML500
C350 CLK55 AMG
C55 AMG
Turn key in electronic ignition to position 1.
Press the system selection button repeatedly until the basic display (kilometer reading or temperature display) appears in the multifunction display.
Press the trip odometer reset button 3 times briefly. A signal tone sounds and the voftage display appears in the multifunction display.
Press lower scroll forward/back button the “Service menu” appears in the multifunction display.
Press buttons + and -‘ setting of specific functions and volume controls repeatedly and select ‘confirmation” menu item.
Press lower system selection button to confirm. “Confirmation appears in the display and the menu ftem “Complete service” is shown against a highlighting bar.
Press lower system selection button to confirm. “Service confirmed” appears in the display.
Press the upper system selection button repeatedly until the “Service Menu” is shown in the display.
Using the + and - buttons, setting of specific functions and volume controls, select menu item “Special work.’ Press lower system selection button to confirm.
Using the + and - buttons, setting of specific functions and volume controls, select menu item ‘Service 13.” Press lower system selection button to confirm.
Using the + and - buttons, setting of specific functions and volume controls, select the specification of the engine oil used “Standard oil” or “Oil quality 229.5.’ Press lower system selection button to confirm.
the message “Item confirmed” appears in the display.”
C350 CLK55 AMG
C55 AMG
03 C32 AMG
There's definitely an easier way. I just did mine last Friday when I did my oil change. I had to play around with the settings a little since there is a lot of info on how to reset the damn thing but not all will work with the C32.
CLS, SLK, ETC
1. click search button
2. type "How to reset service light"
and bam..
https://mbworld.org/forums/c-class-w...ice-light.html
Now, was that so hard? ur welcome
and bam..
c55 amg
and bam..
and bam..
c55 amg
03 g35 coupe...........02 c32 Sold
i always thought you just go to the service miles menu and just hold the odometer button until the reset prompt comes up and just confirm.
its the one thing that i found was easier to do on german cars then japanese cars.
CLS, SLK, ETC
First, I kindly asked you to use search. You couldn't find it (i onno why) so I found it for you. Then you come on here n say thanks for nothing..... Ooookk.. Thats fine but what more should I do for you? Do you expect supa members to fly over there and do it for u?
I'm glad you got everything worked out though. Enjoy ur car
c55 amg
Wait... IT does say noob!! LOL... I jst saw ur join date to fig it out..
First, I kindly asked you to search. You couldn't find it (i onno why) so I found it for you. Then you come on here n say thanks for nothing..... Ooookk.. Thats fine but what more can I do for you? Do you expect supa members to fly over there and do it for u?
I expected nothing but a simple answer nothing more. Not even for you to fly over here and do it for me.
You enjoy your car also. The C55 is an amazing car!
This has been fun... or is there going to be more...
CLS, SLK, ETC
Your kindly was more like do a search "noob", since this has been discussed a thousand times on the board. You could simply provided a link and be done with it or say nothing like most of the other members.
c55 amg
