Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 08-24-2009, 02:38 AM   #1
Drives: CLS, SLK, ETC
Send a message via AIM to Quicktwinturbo
Tap'n gas a little before you downshift..
I do this time to time (usually when I downshift to 2nd or 3rd) and I always wonder if this will harm /stress the tranny... I wish our cars came with nicer tranny
To remove this ad, register today or login if you already are registered!
__________________
Quicktwinturbo is offline   Reply With Quote
Old 08-24-2009, 05:16 AM   #2
MBworld Guru
FrankW's Avatar
Drives: white and whiter
i do it too. doesn't hurt. do it right it blips just before catching lower gear.
FrankW is offline   Reply With Quote
Old 08-24-2009, 07:49 AM   #3
advans's Avatar
Drives: C55 ///AMG, 535xi
Send a message via AIM to advans
I do it too. it should be fine!
__________________
from c320 coupe to C55 ///AMG ________on e9xpost.com________ from 535xi to ///M3 ZCP ___________________on mbworld.org
advans is offline   Reply With Quote
Old 08-24-2009, 11:48 AM   #4
Dingleberry's Avatar
Drives: Marsaydees
Could somebody explain
Dingleberry is offline   Reply With Quote
Old 08-24-2009, 12:32 PM   #5
Drives: 03 C32 AMG
Quote:
Cliffnotes: Guys driving their automatics as if they were manuals.
Never have, never will.
firstshadow is offline   Reply With Quote
Old 08-24-2009, 02:08 PM   #6
1qikctr's Avatar
Drives: Merc power
Ditto here, I think it should be fine.
__________________
A Machine Gun
1qikctr is offline   Reply With Quote
Old 08-24-2009, 02:15 PM   #7
jturkel's Avatar
Drives: 02 C32 AMG
jturkel_bcm
Send a message via AIM to jturkel
i do it too.
__________________
| 02 C32 AMG | SL55 Intake w/K&Ns | LET 185 Pulley | Custom dynotune | LET Heat Exchanger | Eurocharged Headers | Res Delete | NGK IX Iridiums | Magnecor KV85s | NW Pulley Saver | NW ISO Kit | Valentine1 | DashDyno SPD | CF Trunk Lip |
Need to Install: NW oil catch can, C3P I/C Reservoir
jturkel is offline   Reply With Quote
Old 08-25-2009, 01:37 AM   #8
Glad to see some of you does this as welll.. It actually works jst fine if you do it right...
Thanks y'all
__________________
Old 08-25-2009, 01:42 AM   #9
Drives: 06 C55, 09 E350
is that when u hit the kick down switch quickly making the car downshift? My bmw use to do this real well I didnt notice my C55 doing it and I have tried it a few times. I really dont like the shift patterns even in sport mode it seems to shift too early.
__________________
Resonator + Rear Cats Deleted
JonMBZ is offline   Reply With Quote
Old 08-25-2009, 04:18 AM   #10
Quote:
Noooo... You should try ECU - Reset... Do search on how to.
We were talking about just tap'n a gas a litle to match RPM when you downshift (blip)
__________________
Old 08-25-2009, 11:03 AM   #11
oh I see what would be the purpose of this? To make the tires spin or racing situations? I would be afraid to do this myself. I always thought just downshifting would be hard on the trans if the RPMs were too high. I never really knew what a blip was I thought it was a C63 feature so I didn't really care much. I thought about resetting the ECU, but the way traffic is here I figured I might just make it worse than it is now by learning it to my traffic lifestyle. I was thinking a TCU/ECU tune would eliminate it. I read a post I forgot where it stated that a TCU tune would be aggressive all the time in sport and normal in comfort. Thanks for the info
__________________
Old 08-25-2009, 01:17 PM   #12
PC Valkyrie's Avatar
Drives: C55 AMG, 135i M-Sport, X3 xdrive28i
The purpose of the throttle "blip" is the match engine speed with the speed of the drive shaft.
When you downshift (automatic or manual transmission), you will feel an unpleasant "jerk" when the lower gear is engaged because you suddenly force the engine speed to higher values. By blipping the throttle before the lower gear is engaged, you eliminate or minimize that unpleasant "jerk" which could be enough to unbalance the car and cause a spin when cornering on a track.
That's why people who drive manual transmission cars perform "heel'n toe", where they brake and throttle blip at the same time before they downshift and release the clutch to engage the lower gear. The newer dual clutch transmissions and AMG Speedshift Plus (C63) and AMG MCT (new SL63/E63) transmissions do this blip automatically before any downshifts.
__________________
My track videos: http://www.youtube.com/user/PCValkyrie
PC Valkyrie is offline   Reply With Quote
Old 08-25-2009, 02:45 PM   #13
Ok that makes a lot of sense now I guess I will try this out. Thanks for taking the time to explain it to me. I am sure others will enjoy this piece of info as well.
__________________
Tags
bad, car, cost, downshift, downshifting, gas, gun, hit, jerk, machine, manual, shift, tip, tips, tranny, transmission
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
