Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 11-15-2009, 09:55 PM   #1
TemjinX2's Avatar
Drives: 03 g35 coupe...........02 c32 Sold
TemjinX2's s2k projector retrofit.
Hey guys, i wasn't quite as happy as i thought i would be on my tsx retro.
I bought some s2000 projectors for insanely cheap.
So I decided to pick up some new aftermarket head lights with a completely clear head light cover with no glare lines.
s2000 projectors
with the head light cover off.
here's the vision, s2k projector with the head light cover on mock up
To remove this ad, register today or login if you already are registered!
TemjinX2 is offline   Reply With Quote
Old 11-15-2009, 09:58 PM   #2
TemjinX2's Avatar
i'm using door mending brackets to hold the s2k projector
drilled the holes to hold the screws
here's a pic of the cut off.
s2k projecter with shield spacer 35watt with stock philips 4300k
as you can see even with 4300k bulbs, the s2k projectors produce a lot of blue
Old 11-15-2009, 10:01 PM   #3
TemjinX2's Avatar
i should have more updates soon. i bought the wrong nuts to hold my screws so i need to go back and buy some new ones. This retro seems a lot easier then my last one.
If i used some fx-r's or tsx's projectors, this would probably be more of a bolt on project. The s2k lacking any real mounting holes is adding some additional challenges.
Old 11-16-2009, 10:17 AM   #4
Biscuit's Avatar
Drives: 2003 C32
I like this. I squeezed in a set of infiniti fx projectors into the black depo housings with a set of new lenses with edge grinding done. Puts off the same nice blue flair like that does and I love it. :-) (It was also a huge pain in the butt to do...I don't recommend it...)
Good luck!
__________________
Clarion / Image Dynamics / Elemental Designs / Rockford Fosgate setup
LET 185mm -- LET Tune -- C3P Intercooler Reservoir -- DIY C3P Intake
Biscuit is offline   Reply With Quote
Old 11-16-2009, 12:01 PM   #5
TruTaing's Avatar
Drives: w203 m112
Man... I thought your tsx retrofit was pretty dang good. Must visit HIDplanet more often. haha. Nice work! the s2k cutoff is just amazing.
__________________
TruTaing is offline   Reply With Quote
Old 11-16-2009, 04:23 PM   #6
TemjinX2's Avatar
thanks guys. i got a pretty smoking deal on the s2k's that i couldn't pass up. This project is actually a lot easier then my other one. I'm just being kinda lazy and just taking my time.
Old 11-23-2009, 03:52 PM   #7
TemjinX2's Avatar
here's some new pics. i lost some sharpness in my cut off when i installed my chinese 5k bulbs. i'm guessing its because the chinese bulbs aren't made to oem spec like the philips bulbs and therefore changing the distance between the bulb and light shield.
but here's the pics mounted on my car. they look great. I miss the wide beam of a tsx but i do like the brightness of the s2k.
Old 11-23-2009, 04:37 PM   #8
TruTaing's Avatar
Drives: w203 m112
Nice job! I wanna see ya a retrofit on the fogs *hint hint*
__________________
Old 11-24-2009, 04:28 AM   #9
TemjinX2's Avatar
i would but its not worth it since its glass. they already have projector fogs though. Maybe some tsx fog lights..lol.
Old 11-24-2009, 09:56 PM   #10
TemjinX2's Avatar
i fixed my blurrness. I went back to the stock s2k lens instead of the tsx replica lens and i put back the philips 4300k bulbs. The cut off is much sharper now.
i'm pretty happy how the rotational alignment turned out.
No flash at iso 250
Old 11-24-2009, 10:59 PM   #11
W203Ramos's Avatar
Drives: '03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
LOOKS COOL !!!!!!NICE JOB!!!!
__________________
AMG Northeast member
AMG Orphans Club International #87
Code 3 intake
K&n filters
Johnson cm 30 pump
Iso. Kit
Secondary cat delete (2.5 SS)
CF Trunk Lip
19" MMR GT-1
Clear Side Markers
Pulley and Tune Clear HID 4300k projector fogs.(soon)
W203Ramos is offline   Reply With Quote
Old 12-14-2009, 04:02 PM   #12
Drives: C32 AMG
awesom.... i have a few sets of S2k headlights and did the same thing a few months back.... also did HID projectors in my fogs. that was a pain tho. NICE WORK!
dlwiser is offline   Reply With Quote
Old 12-14-2009, 04:05 PM   #13
TemjinX2's Avatar
Quote:
you should post some pics. i'm interested in what kind of work others have done.
Old 12-14-2009, 04:11 PM   #14
Drives: C32 AMG
will do
ill take some of the actual headlight construction now and post up.
Old 12-17-2009, 01:02 PM   #15
TemjinX2's Avatar
what projectors are you using? The Z step looks very thin.
Old 02-27-2010, 05:22 PM   #16
seagel1000's Avatar
Drives: 05 C230 Kompressor
Bump!
I'd like to see this posted up! (materials, steps, places or links to buy the items needed to do this project).
Chris
__________________
05 C230K Blk/Blk Fact. Chrome 17"s Navi Pckg, HK Sound Pckg Sunroof Pckg, CL Grille, White Flat Hood Badge... Other wise stock. "I'm home sick, this body's a temp, Heavens where Home is, I guess it's safe to say that God's people are homeless. - Da.T.R.U.T.H
seagel1000 is offline   Reply With Quote
Old 02-28-2010, 03:41 AM   #17
TemjinX2's Avatar
hey chris,
sorry i missed it on your PM. I'll sell you my old setup for the price i mentioned in the PM. The passenager one is already mounted and aligned. All you would probably need to do is lower it since i aimed them high since i was lowered. All you would need to do is retro the driver side.
Let me know, I can meet you somewhere in the middle.
Old 02-28-2010, 03:43 AM   #18
TemjinX2's Avatar
There's a more detailed item list on my original tsx thread.
The screws and washers i used for this project are the same as my tsx thread. Hope this helps.
http://forums.mbworld.org/forums/c32...t-project.html
Old 02-28-2010, 05:00 PM   #19
seagel1000's Avatar
PM'd back!
Chris
__________________
Old 04-30-2010, 05:23 AM   #20
Drives: nissan
they looks cool dude
__________________
ERWIn
erwin.zeez is offline   Reply With Quote
Old 04-30-2010, 06:18 AM   #21
TemjinX2's Avatar
Quote:
thanks man. I love them. I love the color and intensity.
Old 06-04-2010, 01:27 AM   #22
Drives: 2003 C230 Coupe
Hi, I have a coupe and want to do a retrofit. What all would I need to get in order to do it? With first being some headlights since i have the fogged ones.
EuroMerc311 is offline   Reply With Quote
Old 06-04-2010, 11:43 PM   #23
TemjinX2's Avatar
i'll try to take some more shots later. I'm very happy with the retrofit. I drove it around LA last night and on the freeways.
Here's a materials bought break down
1. eagle eye black head lights $207
2. tsx projectors $160
3. harness $45
4. 50watt hid ballasts and bulbs $150
5. miscellous screws, bolts and springs $30
6. oem nissan sealant $20 per roll (bought 2, only needed 1 )
total $632
retrofitted tsx projectors priceless.
items used, but not bought
drill
dremel
heat gun
300watt computer ps for ballast testing
most of the details are on my tsx thread. Its basically the same as my tsx thread except there's less drilling involved with the sonar head lights.
updated 5-9-08
i figure i would give a update. I'm almost done with the first side. i might do a little more of a adjustment then start on the second side.
here's a pic of the cut off with 3 washers on the bottom holes
i drew out the mounting holes with a blue pen
here's my projector setup
i used 8-34 screws with 8-34 nuts. I added rubber stoppers as well to relief some pressure being put on the plastic reflector. I added springs as well between the top of the projector and where the screws meet the reflector.
The spring is designed to keep tension on the projector so it will absorb the impact when you go over a speed bump. Without it, you'll notice your light will flicker when you go over bumps or drive on a bumpy road. It doesn't do anything to the bulb, but it gets kind of annoying.
When i mounted this i realized its better to have the screws facing the other way. This way you can just tighter the nut and adjust for the rotational, the tension from the spring will keep the projector moving in or out based on how i tighten the nut.
here's a pic of it mounted to the reflector
pic of the rotational once mounted on the reflector
its slightly off to the right, but i think i can live with it. I might adjust a little more later before the jb weld.
Old 06-04-2010, 11:44 PM   #24
TemjinX2's Avatar
you don't need a the hid harness, since the oem harness seems to be robust enough to handle the amps.
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
amg, c32, carputer, clarion, cxs62, dynamics, fog, image, infiniti, lights, projector, retrofit, s2000, s2kr, tsxr, vrx775vd, vs
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
