View Poll Results: should this thread be a sticky ?
Yes
66.67%
No
33.33%
Voters: 3. You may not vote on this poll
Mercedes Error codes
Old 03-16-2014, 05:15 PM
  #51
shaun.barnard's Avatar
'09 ML 500 (550) Off road Package
Radio not asking for codes? Wierd.
Old 05-15-2014, 10:39 AM
  #52
goce16's Avatar
mercedes w211 e200 kompressor
fault code 201C
Hi, I have fault code 201C
the composition of the mixture is rich
W211 Mercedes E200 Kompressor 2005y
the engine is 271.941
fuel consumption is increased and the power of the engine is litle lower
any ideas how to fix would be great
Thank's
Old 07-08-2014, 05:42 AM
  #53
reggy's Avatar
benz sprinter 311 cdi
hey im new.my mb sprinter is not starting with a code crankshaft position sensor a range performance.tested contiuety from the sensor tothe computor box ,and its .now tested the sensor ,its ok and i even move on to replace it.cleared the code tried it but stil not starting and the code is back agai.any help please
Old 07-17-2014, 02:33 AM
  #54
abcd690827's Avatar
C32 AMG
WOW...............Specialty
Old 07-17-2014, 08:14 PM
  #55
Tanche's Avatar
mercedes e200
Can you please tell me how you solve your problem?
I have the same codes and symptoms almost 2 months.
Old 09-08-2014, 05:44 AM
  #56
JiminSA's Avatar
Shanks's Pony
Transmission error codes
I am having difficulty finding error codes PL1731 and PL2784 on the web and have joined your forum in the hope that someone may please help me. Is there an online lookup facility anywhere?
Old 11-13-2014, 03:11 AM
  #57
marshygwanzy's Avatar
c200 kompressor 2003
hi..
how did you fix your P201C error.i have a 2002 c200 kompressor with a 271 engine.it also has the P201C error code and also P0171 and P2029 error codes. ive changed a cracked hose under the airbox already but the check engine light keeps coming back. i also changed the cam shaft magnets and the connector wires from the magnets and the upstream o2 sensor. the car drives better but fuel consumption is still high and 5 days ago it did the jerking thing whilst i was stopping at a red light.
Old 09-19-2015, 01:31 PM
  #58
Anh HÆ°ng's Avatar
mercedes
Mercedes S Class CABRIOLET Footage 2016
Old 10-14-2015, 09:35 AM
  #59
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
WTG great post. I'm going to save this for future reference. If it's cool I'll link to this post in the W212 side.
Old 05-19-2016, 04:59 PM
  #60
afk
afk's Avatar
2003 Mercedes C32
I got error code P0410
Hi, I am new menber
I got this code P0410. what exatcly means. what shoud I fix it ?
thx !
Old 05-20-2016, 01:15 PM
  #61
ban.benben's Avatar
c220 cdi
Hi, I am new menber
I have two questions.
I got this code P0272. what exatcly means. what shoud I fix it ?
and How can I do reset to computer?
I have mercedes c220 cdi 2007
thx !
Old 05-27-2016, 03:51 AM
  #62
afk
afk's Avatar
2003 Mercedes C32
Originally Posted by ban.benben
Hi, I am new menber
thx !
I am new member too. to reset and read the codes get a obd2 scanner from ebay or amazon for $15. I bought the Obdii Scanner Code Reader Can Maxiscan Oxgord Ms300 comes with manual with a list of codes.
Old 04-26-2017, 08:24 AM
  #63
gauchobenz's Avatar
01 MB C320
01 MB C320 (W203) codes?
I, know is an old thread but my 01 C320 is driving me crazy with ESP going on a "limping mode" at the worst possible moment and this codes could be a life saver (thanks a lot for posting)
my question is:
are these codes for a 2001 MB C320 (W203) ???
Old 05-25-2017, 12:56 AM
  #64
Kamui's Avatar
Mercedes Benz W203 AMG MOD,2016 Lexus GSF, 2006 Mercedes Benz E350, 2004 BMW 325i, 2016 Ducatti Mons
Not sure what you are asking, but I am guessing that you have issues with your ESP? What exactly is it doing?
Also, W203 are all Mercedes models produced (actual production began in July 2000 through Dec 2006) from 2001-2007
Old 05-25-2017, 07:21 AM
  #65
gauchobenz's Avatar
01 MB C320
Not asking anything, wanted to corroborate if those codes were for my 01 MB c320 (W203) as well, basically just trying to give thanks to the person that posted the fault codes
have a great one
What it does when the ESP fault appears?
what all do, goes to a "limping or emergency mode "
Old 01-29-2020, 08:00 AM
  #66
Rudy El Haber's Avatar
C230 Kompressor 2005
Hello,
I had the following error codes on my C230 Kompressor 2005 model:
P2041 + P202B + P202D
When Cold the car hesitate and stumble,
Please if you can assist,
Thank You.
Old 09-01-2022, 06:07 PM
  #67
stevekrupp's Avatar
2004 SLK32AMG
The list of codes such as PO....... that are posted above would they apply to a 2004 SLK 32 AMG model ? The PO looks like most standard car codes. I have a problem I need help with. After changing a dead battery I can not get the car started anymore. It started fine initially after the battery change a week ago. Bur now it will not start. If I turn the key back and forth long enough it may start and fires up and immediately dies and displays Start Error and the #88 appears in the odometer along with the MB wrench symbol. Form other forums I have tried cleaning prongs on fuses # 9, 35 and 37 but this seems to be a communication problem between the key and the computer or the interface between these. I got three keys with the car years ago and tried different keys but no luck. I was having this starting issue for about a year before the battery finally went dead. I replace the battery with A Walmart 720 CCA the came exact battery as the MB battery, I have seen a reference to a K-40 relay and also some talk of a bad starter switch but all the lights on the dash come on with every turn of the key just no start. Does anyone know what the #88 means ? and how id this solved ? Thanks
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Mercedes Error codes
