Sign in using an external account
| C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 05 Acura TL and 05 C55
C55 Bizarre Problem
#2 |
Drives: 2005 Pontiac GTO 6.0 LS2 - Blue
More than likely it's the CPS (crank position sensor). It's a common problem...
__________________
SOLD ![]() 2002 C32 AMG Sedan [132,000 Miles] Clear Side Markers | CL Style Grille | Flat Emblem | CF Front Lip Spoiler | CF Rear Diffuser | CF Trunk Spoiler K&N Air Filters | NGK IX (2 Step) | KV-85 | 185MM EUROCHARGED | TVT Thermostat | PSK Belt Wrap Johnson CM30 | DIY Intercooler Isolation | 26x7x2 FB H/E | A/F & PSI Pillar |
#3 |
Drives: 2005 C55, 2007 Trailblazer SS
Get that code read ASAP. Get over to an Autozone or something and they should still be able to pull the code from it.
#4 |
Drives: 2006 C55 AMG
Crank Position Sensor definitely...
#5 |
yeap, most likely CPS
__________________
![]() from c320 coupe to C55 ///AMG ________on e9xpost.com________ from 535xi to ///M3 ZCP ___________________on mbworld.org |
#6 |
Thanks for the reply guys, I know I should search, but is the CPS something that will harm the car? My dad and I push the car all the time and last night was the first time that happened.
#7 |
Has this problem repeated at all? If not I would just wait on it, and see if it does. At that point I would replace CPS. Check for pending codes...
__________________
#8 |
Not since, no... I was reading through some threads, and it seems that the problem will persist getting worse each time; eventually leading to the car shutting off while driving?!?!
#9 |
AHHH! The car died on my dad today. We'll take it to our dealership, however I heard you can get the sensor much cheaper elsewhere? I also heard it is a pain to remove the old sensor and install the new one. Does anybody have insight on this?
I was thinking about asking the part/service guy to show me a diagram of the location or something... we shall see.... |
#10 |
HA! Merc of Calabasas wants $500+ for the sensor and labor... I found an Indie shop in the SFV that Will do it for about 200 (sensor and labor). Has anyone heard of MBZ Motors on winnetka and Roscoe?
The annoying this is, I think I'm mechanically inclined enough to swap out the senor myself... if I knew where it was and what tools were needed. |
#11 |
I could look into it for you if you get no replies from people who have already done the swap. Yes, parts can print you out a diagram, and yes, you can find the sensor cheaper than at the dealership. Autohausaz is one of my main suppliers. I would assume the job isn't too terribly hard, but in a lot of cases special tools are required. You can consider the cost of tools, and all to still be saving money compared to having someone do it for you. Then you will also have the tools if ever needed again... By the way, I've heard numerous complaints about Mercedes of Calabasas when I was searching for my C32! However, all the dealerships tend to be the same, and have terrible customer service. I always find the parts associates to be the only ones friendly, and helpful. At my local dealership I only trust, and get along with three people. Two work in parts, and the attractive receptionist...
__________________
SOLD ![]() 2002 C32 AMG Sedan [132,000 Miles] Clear Side Markers | CL Style Grille | Flat Emblem | CF Front Lip Spoiler | CF Rear Diffuser | CF Trunk Spoiler K&N Air Filters | NGK IX (2 Step) | KV-85 | 185MM EUROCHARGED | TVT Thermostat | PSK Belt Wrap Johnson CM30 | DIY Intercooler Isolation | 26x7x2 FB H/E | A/F & PSI Pillar Last edited by gt4awd; 02-23-2010 at 12:28 AM. |
#12 |
Drives: C55 AMG, Viper GTS
just diy...
__________________
'05 C55 AMG | Diamond Black | Black Nappa
#13 |
What is the crank position sensor exactly?
__________________
![]() Secondary cats and Resonator Deleted and K&N Air Filters. Carbon fiber front lip,Black grille,Black taillights. 13.04 1/4 mile at 107 mph before secondary cats were deleted. http://www.youtube.com/watch?v=Fs-gWG3TnM4 1/4 mile run |
#14 | |
Quote:
I would if the 55 was my car, but my dad feels better having the indie shop do the work. Don't quote me on this, but from what I understand, the sensor will not allow fuel to be distributed until the sensor gets a signal... Might want to do a search of your own, it appears that several C32s and C55 have this problem
| Tags |
| add, amg, c32, c55, carbon, crank, diffuser, lights, position, problem, rear, sensor, style, tail, w203 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
