Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-23-2010, 09:20 PM   #1
AMGSC's Avatar
Drives: C55K, M3TT, MV Agusta F4, Daytona 675, Ducati 999R, 14lb CF road bike, 16lb Titanium MTB
I am a bonehead! OK to insult me this time.
I can't believe I did this.
Took the car for another dyno test to be followed by a compression and leak down and made a really stupid mistake.
I brought along a 5Gal drum of VP MS109 gasoline and had the operator start pouring it into my gas tank. He sees that the gas is cloudy and asks me how old is this gas. I explain that it has been sitting in my garage for at least a year or two. He continues pouring and then sees red color in the liquid. He immediately stops pouring and tells me that its rust. I think by this time, he's poured in 1-2 gallons into the tank already.
He starts up the engine and begins to make the first dyno run and gets up to 325+rwhp with a nice AFR of 11-1 and then suddenly the engine starts stumbling, the AFR spikes the engine begins to cut out. It finally just shuts off. He restarts it and listens closely to the engine while it stutters, putts and chokes in limp mode. He shuts down the car.
We both check the label on the drum and he looks up the internet gas brand and formula. The gas brand and formula comes up as unleaded and fine to run in my car. He then asks me if I ever added anything to the drum.
Then all of a sudden it dawned on me! I had already used up all of the MS109two years ago and used the drum to hold methanol and water 50/50 mix for my CoolingMist system back then.
End result: I now have to pay $900 to drain the tank, flush ALL the fuel lines AND ultrasonically clean all the injectors. So basically, I made a $900 mistake but several experts told me the engine suffered no damage. I'm still paying another $300 for compression and leak down test and $125 for the aborted dynorun. So this mistake ended costing me a total of $1,325.
Maybe that's why dyno shops should never trust any race gas a customer brings in. It just might be water mixed with methanol.
I am truly a bonehead and deserve a few insults.
To remove this ad, register today or login if you already are registered!
__________________
Perf Mods:DYNOCOMP/EVOTECH tuned |9:1Mahle pistons&rods|Ported Kleemann TS SC|ECU|TCU|Cams|MBH Headers|Ported Heads|Oversized valves|E55 injectors|Dual 3" exhaust|65mm/170mm pulley combo|82mm TB|Dual 3"CAI with K&N cone filters|CM90|5Gal resevoir|Code3FMHE|PTE T-Stat|Quaife|Maybach Trans|HSTC|Phenolics|Brembos|H&R sways|Bilstein PSS9|MbArts camber kit|Speedybenz toe kit|Kmac caster kit|Braile|CCW|MT|FG vented hood&fenders.
AMGSC is offline   Reply With Quote
Old 03-23-2010, 09:36 PM   #2
Drives: 2002 C32
I think you're about to take enough of a beating already.....speechless.
__________________
Always,
--Gramma_Benz--
MY Eurocharged BEAST
EUROCHARGED 185mm Crank Pulley, EUROCHARGED Shorty Headers, EUROCHARGED Heat Exchanger & Custom 185 Eurocharged "Jerry" Tune, SL55 Full Intake, Carbon Fiber front lip, K&N's, IK20's, Sprintbooster, Resonator Delete, Johnson CM30, Tein Basic Coilovers, NeedsWings Pulley Saver Kit
Latest Jerry Tune= 372RWHP 360RWTQ
Me on YOUTUBE: Finishing off tires
Gramma_Benz is offline   Reply With Quote
Old 03-23-2010, 10:44 PM   #3
SPONSOR
hooleyboy's Avatar
Drives: R.I.P C55./ 2005 SL55
O boy. Now you know never ever ever use old fuel.
__________________
hooleyboy is offline   Reply With Quote
Old 03-23-2010, 10:55 PM   #4
TemjinX2's Avatar
Drives: 03 g35 coupe...........02 c32 Sold
well at least you didn't ruin the engine. Hope everything works out.
TemjinX2 is offline   Reply With Quote
Old 03-23-2010, 11:47 PM   #5
02C32guy's Avatar
Drives: 2002 C32
I thought for sure you were going to say it was two cycle mix. I'm always worried that I'm going to do that by mistake.
__________________
C3P SC Pulley, C3P Reservoir, C3P HE, NeedsWings Dual CAI, CM30 icp, NW PSK, RacingBrake Open Slotted Floating Rotors, Porterfield RS4 Pads, Goodridge Lines, ATE Super Blue, Res Delete, ARGOS
Mercedes Benz Owner's Gun Club Member #84
02C32guy is offline   Reply With Quote
Old 03-24-2010, 12:11 AM   #6
e1000's Avatar
Drives: a quarter mile at a time
ouch, that sucks. At least there was no damage.
__________________
e1000 is offline   Reply With Quote
Old 03-24-2010, 12:26 AM   #7
AMGSC's Avatar
Quote:
OOOPs! Dyno guy didn't know either cuz I told him it was at least 1yr old and he kept pouring but at least watched the color carefully. I guess better late than never. If the entire 4 gallons went in before dyno was run then engine damage may occur.
__________________
Old 03-24-2010, 12:57 AM   #8
saer1one's Avatar
Drives: 2002 c32 amg
Quote:
hey, **** HAPPENS.. just glad nuthing else happened to the motor..
__________________
saer1one is offline   Reply With Quote
Old 03-24-2010, 01:10 AM   #9
SUPR C's Avatar
Drives: 02 C32, G60 Corrado
Glad your motor is ok. As stated above **** happens.
SUPR C is offline   Reply With Quote
Old 03-24-2010, 01:29 AM   #10
SPONSOR
MBH motorsports's Avatar
Drives: SL55
MBH Motorsports
Only thing I put crappy old gas in is my lawn mower... Seems to run great lol. Race fuel will go bad right before your eyes. Leaving it trackside in a sealed plastic fuel jug, will kill the fuel fast, Letting it sit in open air, sunlight, a long time, will all make fuels go bad.
if you buy race fuel, you have to use it right away.
__________________
Contact me directly for best available pricing
mike@mbhmotorsports.com
http://www.mbhmotorsports.com
Direct Number (623) 377-4624
Now available: CLS63/E63 BiTurbo Downpipes, CLS550/E550 BiTurbo Downpipes, C63 Strut Tower Brace.
MBH motorsports is online now   Reply With Quote
Old 03-24-2010, 02:18 AM   #11
AMGSC's Avatar
tip to live by from now on! Thanks! You da man!
__________________
Old 03-24-2010, 02:28 AM   #12
jturkel's Avatar
Drives: 02 C32 AMG
jturkel_bcm
Send a message via AIM to jturkel
you should run C16 in your lawn mower....didnt you tune for it in the mower anyway? lol
__________________
| 02 C32 AMG | SL55 Intake w/K&Ns | LET 185 Pulley | Custom dynotune | LET Heat Exchanger | Eurocharged Headers | Res Delete | NGK IX Iridiums | Magnecor KV85s | NW Pulley Saver | NW ISO Kit | Valentine1 | DashDyno SPD | CF Trunk Lip |
Need to Install: NW oil catch can, C3P I/C Reservoir
jturkel is offline   Reply With Quote
Old 03-24-2010, 02:38 AM   #13
Drives: E CLASS
**** happens...learn from your mishap...for future reference...LABEL YOUR CANS
GL
NORCAL///AMG is offline   Reply With Quote
Old 03-24-2010, 12:24 PM   #14
AMGSC's Avatar
Quote:
GL
Now why didn't I think of that. Imagine if I replaced the contents of prescription drugs with some other drug without re-labeling. Come to think if it I think I've done that before too. Glad I'm still alive. I think alzhiemer's is settling in a little early for me.
__________________
Old 03-24-2010, 12:29 PM   #15
AMGSC's Avatar
I just got a great tip from a source I will reveal later. No need to drain the tank. Just pump the fuel out into a bucket by running the fuel pump. Then put in an additive from Autozone that takes out the trace amounts of water still in the injectors or lines. Then refill tank with 93Oct to dilute the trace amounts of water still left. That tip just saved me at least 6hrs of labor.
__________________
Old 03-24-2010, 12:37 PM   #16
Drives: '05 Crossfire SRT-6
I remember doing that to loung14's old C32 last July before HIN seeing as he had a full tank of gas and HIN said no more than 1/4 tank in the car when the car enters the show... That was an interesting event. Just make sure you pull the hose off the correct side so that it properly enters your bucket of choice.
overall, gald to hear no engine damage was done. everyone as hiccups, just gotta work through em keep on going.
__________________
-Matt
2005 Chrysler Crossfire SRT6
"You can pay for school, but you can't buy class"
ZAHANMA is offline   Reply With Quote
Old 03-24-2010, 01:43 PM   #17
c32kompressor's Avatar
Drives: c32 amg
thats good that theres no damage to your car. but be careful lol
__________________
c3p intake, secondary cat and resonator delete, DIY intercooler separation, intake baffle removal, custom 69mm s/c pulley, Eurocharged Tune.
c32kompressor is offline   Reply With Quote
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
