Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-26-2010, 02:12 AM   #1
mikekuriger's Avatar
Drives: c55
repacing motor mounts on c55
OK, so I found a thread on here that said changing the motor mounts was fairly easy. I can't seem to find it now sadly. Anyway, I changed my tranny mount in ike 5 minutes, but it took me an hour to change the passenger side motor mount. The first snag was the fact that I could not figure out what size wrench to use on the top bolt. (5/8 ") once I figured that out after much trial and error, I finally got the mount out. welcome snag #2. I was unable to get the mount out because the exhaust was in the way towards the rear and various other stuff in the way in every other direction. Finally, I disconnected the mounts that hod the sway bar on and dropped the motor mount out.
This weekend I want to do the other motor mount on the drivers side. Does anyone know how to get that one out? I don't want to try dropping the exhaust unless that's the only way. The AC compressor looks to be in the way to get the mount out the same way I did on the passenger side.
any help would be great!
Mike
To remove this ad, register today or login if you already are registered!
__________________
Mike
2005 C55 AMG tuned by OE tuning, 180,000 + miles
mikekuriger is offline   Reply With Quote
Old 03-26-2010, 05:26 AM   #2
Viper98912's Avatar
Drives: C55 AMG, Viper GTS
What was the reason for you to change the motor mounts?
__________________
'05 C55 AMG | Diamond Black | Black Nappa
Viper98912 is offline   Reply With Quote
Old 03-26-2010, 06:26 AM   #3
Drives: CLS, SLK, ETC
Send a message via AIM to Quicktwinturbo
Quote:
They go bad ard 30-40k miles.
I need to replace mine (tranny + motor mount).
Primary symptoms of bad motor / tranny mounts:
Little or strong viberation (steering wheel, seats, etc) when you are in D or S..
__________________
Quicktwinturbo is offline   Reply With Quote
Old 03-26-2010, 04:05 PM   #4
Viper98912's Avatar
I've been wondering if mine need to be replaced. At highway speeds (70 mph), they sometimes come and go, but I don't know if it varies due to road surface. Once you go up to 80+ then try to level off/cruise, it begins to shake again and then levels off. I'm waiting more to buy new tires and look at my CA bushings, then move on to the mounts.
__________________
Old 03-27-2010, 03:33 AM   #5
Drives: c55
the symptom of bad motor mounts is vibration at idle, especially when in reverse or drive. you can't tell when driving. I have over 100,000 miles now and the mounts are toast.
__________________
Mike
Old 03-27-2010, 03:34 AM   #6
Drives: c55
oh another symptom was I could hear the engine clunk when going over speed bumps.
__________________
Mike
Old 03-27-2010, 11:51 PM   #7
alpha8a's Avatar
Drives: '05 C55 AMG
I have 62k miles on my car now and the motor mounts are on their way out. The car shakes a little during idle. How much are you guys paying independent mechanics to have these changed out?
__________________
- Andrew
'05 C55 - Resonator Delete, Secondary Cats Delete, V1, ZR4 Shifter
alpha8a is offline   Reply With Quote
Old 03-28-2010, 06:24 AM   #8
dkflipse's Avatar
Drives: C32 AMG
Quote:
I paid $350 in labor to replace both the engine and tranny mounts.
__________________
Renntech Stage I, Y-Splitter, H&R Springs, 352 RWHP/361RWTQ
http://forums.mbworld.org/forums/sho...69#post2565669
dkflipse is offline   Reply With Quote
Old 03-28-2010, 01:26 PM   #9
Drives: c55
The dealer here want's over $450 in labor costs to replace just the drivers side motor mount. Since nobody has chimed in with the procedure, I'm going to do it and post pics and create a howto for all yall!
~Mike~
__________________
Mike
Old 04-09-2010, 05:08 AM   #10
Drives: c55
I finally got around to replacing my driver's side motor mount. At first, I was going to give up because there is just no room to get the MM out without removing the exhaust. However, I discovered a way to do it and other than that top bolt being really hard to get off it wasn't that hard. I'll post pics and a DIY since I was unable to find this info online.
By the way, after replacing the mounts the speed bump "clunk" is gone (thought my struts were bad) and I can't even tell the engine is running anymore. It used to vibrate the car, especially in reverse. The stock MMs were so bad that the rubber was dried up, no oil, and they basically fell apart when I took them out.
~mike~
__________________
Mike
Old 08-03-2012, 10:06 PM   #11
Drives: Mercedes AMG C55, BMW 4.8is
@vournazos
Replace one engine mount?
Hi guys,
Sorry to re-open an old thread, but couldn't find the answers I was looking for in a search.
Just had my c55 diagnosed with a leaking LHS Engine Mount, and a RHS mount that is "soft".
The car is under warranty for another 2 months or so, but the dealer only wants to replace the LHS mount as he says that the RHS one is still OK, and that it is normal for it to last longer than the LHS as one side typically takes most of the strain.
Every time I've seen this done, both engine mounts are usually replaced, so this doesn't make sense to me, and I think he's just trying to put if off until the car is out of warranty. I'm insisting that he replaces both, but want to present some good arguments why.
Are any of you aware if there is any evidence to suggest that one side will wear significantly faster than the other and if he is correct?
Better still, is anyone aware of any Mercedes Service bulletins that recommend replacing both at the same time that I can refer to?
Thanks in advance for your help.
Black5 is offline   Reply With Quote
Old 08-04-2012, 12:05 AM   #12
Drives: 1975 280C, 1989 300E, 2005 C55
Did you guys buy genuine Mercedes-Benz mounts to do this or did you go aftermarket? Also, where can I find the torque specs for the motor and transmission mounts?
I assume you used a thick flat solid wood board and lifted the engine using a hydraulic floor jack in conjunction with this board.
__________________
2005 C55 AMG @ 92,000 miles
1989 300E @ 220,700 miles
Rahulio1975280C is offline   Reply With Quote
Old 08-06-2012, 08:27 PM   #13
Drives: 2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
I had mine done at the dealer for $750 all in for both mounts and tranny. Hope someone eventually steps up and makes polyurethane mounts.
__________________
SL55 rims, 235/40/18 and 275/35/18 Dunlop Direzza Star Spec tires, KMAC front camber bushings. Some fender grinding.
kent426 is offline   Reply With Quote
Old 09-11-2012, 01:02 AM   #14
ghiaguy's Avatar
Drives: C55 AMG & Karmann Ghia
bump - any info on diy for the drivers side. I want to replace the only one thats bad. thx
__________________
ghiaguy is offline   Reply With Quote
Old 09-11-2012, 02:59 AM   #15
rlddlr53's Avatar
Drives: 05 C55 AMG, 04 CLK55 AMG
Just had mine done. $200 for labor and Mounts for $60 each for Lemfoerder
__________________
<!-- Begin Official PayPal Seal --><a href="https://www.paypal.com/us/verified/pal=Mutsydog%40aol%2ecom" target="_blank"><img src="https://www.paypal.com/en_US/i/icon/verification_seal.gif" border="0" alt="Official PayPal Seal"></A><!-- End Official PayPal Seal -->
rlddlr53 is offline   Reply With Quote
Old 09-11-2012, 11:12 AM   #16
ghiaguy's Avatar
Quote:
damn for $200 I guess so- my quote was $600 (with mounts +tranny mount incl) where did you find a shop to do $200?
__________________
Old 09-12-2012, 12:30 AM   #17
rlddlr53's Avatar
In sherman oaks, 91423
__________________
Tags
atlanta, benz, c55, car, changing, engine, ga, labor, mbz, mercedes, motor, mount, mounts, purchase, replace, shudders
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
