Anybody have the intercooler diagram for our c32 kompressor engine..?
Old 10-24-2010, 11:36 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
As the tittle states, would be very helpfull.. Thanks in advance..
Old 10-25-2010, 01:55 AM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
Is this what you're looking for?
Attached Thumbnails Anybody have the intercooler diagram for our c32 kompressor engine..?-c32starintake.jpg   Anybody have the intercooler diagram for our c32 kompressor engine..?-c32starintercooler.jpg
Old 10-25-2010, 03:04 AM
saer1one's Avatar
Exactly what im looking for.. Thanks gt4awd, just gettin prepped up for the new ic pump and ICiso kit..
Old 10-25-2010, 01:06 PM
Newzchspy's Avatar
PLAID
ISo kit works great, you can DIY or use the Needswings, (which I used). It took about less than 10 minutes with their kit
Old 10-25-2010, 02:50 PM
saer1one's Avatar
Yea, i bought the Needswings kit and a bottle of chill charger.. How do you recommend installation..? I kind of have an idea, going to drain and flush the radiator system (what is the best product for a flush..?), replace old IC pump with new, install the iso kit, leave valves open, refill system with new antifreeze, distilled water and chill charger additive, run car thru a full heat cycle until air pockets are out, close valves.. How did you guys do this..?
Old 10-25-2010, 03:03 PM
Newzchspy's Avatar
PLAID
I have used Chill Charger in the past as well as Redline's Water Wetter for the radiator. I did'nt do a change this time, BUT when I did in the past, I always use Genuine MB Coolant. Nothing else.
I ran through 3 heat cycles before closing the Needswings valves. They say One BUT I erred in the favor of caution.
Old 10-26-2010, 12:39 AM
gt4awd's Avatar
I always use the Prestone radiator flush, and haven't had any problems. You can get it at Wal-mart for around three dollars. There's a method to purge the I/C system of air bubbles. Running heat cycle once or twice does an adequate job however. I've previously used Redline's water wetter, but am now going to try Royal Purple - Purple Ice.
I posted a fully detailed DIY thread with photographs over on benzworld...
http://www.benzworld.org/forums/w203...placement.html
Old 10-26-2010, 03:02 AM
saer1one's Avatar
I came across it while i was searching for the IC system diagram. Will definitely use the write up when im performing the job.
Old 01-04-2011, 12:32 PM
alexdmpid's Avatar
C32
I wonder if anyone knows what I have to do to install the intercooler pump Johnson CM30 on my C32, my mechanic is not getting, is there any special support or power supply?
Sorry for my english is terrible!
Old 01-04-2011, 08:57 PM
gt4awd's Avatar
Not sure what others have done, but I'm going to install by placing rubber spacers on the smaller cm30 pump, and use the original bracket.
Old 01-04-2011, 09:04 PM
saer1one's Avatar
I believe the pig tail harness is also different on the CM30..? Correct me if i am wrong..
Old 01-04-2011, 09:15 PM
gt4awd's Avatar
Yes, you need to cut off the original harness on the vehicle, and just splice the wires together... Keep in mind this DIY thread I made is for lightning pump nearly identical to the OE pump. Johnson already has the positive and negative wires installed on the pump.
Old 10-26-2014, 02:45 AM
CALI_1320C32AMG's Avatar
w203 C32 AMG
So basically the bottom graph is a split cooling system right?
Old 10-26-2014, 08:39 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
You can think of it that way but it all depends on how you are going to add coolant to the split system.
Old 10-26-2014, 11:57 AM
w203 C32 AMG
so then i could just plug the yellow as the place to add coolant what about a resivor?
im a c32newbie for this my car is running WITHOUT these hoses on my car ,����������
Old 10-26-2014, 12:08 PM
Lenin's Avatar
Here is some additional reading for you. https://mbworld.org/forums/c32-amg-c...group-buy.html
And I can not emphasize enough. Get familiar with the Search function or this super fast old C32 AMG will cost you lots of $$$$ and you will start hating it very soon.
Old 10-26-2014, 12:12 PM
w203 C32 AMG
ok then forget all this , im just gonna buy this resvior and split the cooling, i just ordered the CM30 pump .. thanks lenin cause im sure your right.
Old 10-26-2014, 12:27 PM
Lenin's Avatar
What reservoir are you thinking of getting? Here is a video of the BMW reservoir install on the E55.
it may give you some ideas.
Michael Hamze (12-24-2017)
Old 10-26-2014, 03:43 PM
w203 C32 AMG
nice now i understand
but what resivor did you use?
Old 10-26-2014, 04:24 PM
Lenin's Avatar
LET 181mm pulley, NW Pulley Saver Kit, NW full intake, 80mm TB, Code3 HE, Code3 Reservoir (separated cooling), Meziere pump, Kleemann Headers, Supersprint dual exhaust, Eurocharged ECU & TCU tune, Quaife LSD, Bilstein PSS9, CLK 63 front/rear brakes, Zeitronix/DashDaq data logging
Old 10-29-2014, 12:29 AM
w203 C32 AMG
@lenin my charge air intercooler is hooked up to itself.
Quick Reply: Anybody have the intercooler diagram for our c32 kompressor engine..?
