Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-08-2011, 04:00 PM   #1
Drives: 2004 C32 AMG
Battery
I need a new battery for my car has anyone used the Shuriken Light Weight Battery Kit from needswings? Was thinking that one or an optima although there a lot more but also would an optima even fit?
To remove this ad, register today or login if you already are registered!
spatton is offline   Reply With Quote
Old 05-08-2011, 05:16 PM   #2
320 dreamer's Avatar
Drives: 2003 porsche 996 turbo
Send a message via Yahoo to 320 dreamer
i have the shuriken battery. if you don't drive your car every day you need a trickle charger the shuriken has only 30 amp hrs or so and the larger battery in your car has somewhere around 70 amp hrs. the static drain will kill the little battery if you don't drive it every day or charge it. great for racing but wouldn't recommend it unless you want it for racing to drop around 25 lbs or so
320 dreamer is offline   Reply With Quote
Old 05-08-2011, 05:55 PM   #3
02C32guy's Avatar
Drives: 2002 C32
Quote:
I have the shuriken. What 320dreamer said is true though I've left the car for three or four days without any problems. If you drive a C32 you'll have to fabricate a tie down for it.
__________________
C3P SC Pulley, C3P Reservoir, C3P HE, NeedsWings Dual CAI, CM30 icp, NW PSK, RacingBrake Open Slotted Floating Rotors, Porterfield RS4 Pads, Goodridge Lines, ATE Super Blue, Res Delete, ARGOS
Mercedes Benz Owner's Gun Club Member #84
02C32guy is offline   Reply With Quote
Old 05-08-2011, 06:07 PM   #4
thanks for the input
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
