Sign in using an external account
| C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: Multiple
AZNOptics LED wiring DIY?
__________________
08 4Runner | 12 Ducati 848 Evo Corse | 07 KLX351 Previously... 06 C55 AMG | 04 Ducati 749 | 07 Ducati S2R1000 | 03 BMW F650CS | 05 BMW M3 | 00 E55 AMG | 05 RSX Type-S | Other stuff not worth mentioning... Last edited by xxaarraa; 06-03-2011 at 10:30 AM. |
#2 |
Drives: 2009 C 63
hi
my auto elec. said can not do if u find solution please share thanks. regards george
#3 |
Drives: Marsaydees
Your DIY will be much easier if you would settle on having the LED's turn on when the ignition is turned on and turn off when the ignition is turned off.
#4 |
Drives: 2009 C 63
any helpfull coments ? thanks
#5 |
Drives: 2009 C 63
no comments ?.
#6 |
Drives: 2009 C 63
come on guys any imput thanks.
#7 |
Drives: Multiple
I may be able to live with that if it saves a whole lot of head ache. Which wires would I have to splice?
__________________
08 4Runner | 12 Ducati 848 Evo Corse | 07 KLX351 Previously... 06 C55 AMG | 04 Ducati 749 | 07 Ducati S2R1000 | 03 BMW F650CS | 05 BMW M3 | 00 E55 AMG | 05 RSX Type-S | Other stuff not worth mentioning... |
#8 |
Drives: 2009 C 63
any inf
![]() o on any method of wiring would help thanks.
#9 |
Drives: 2009 C 63
stuffed up my last post sorry.
#10 |
Drives: Marsaydees
You want to stop your spam yet?
#11 |
Drives: Multiple
Dude if you know the answer and want to help, post it up. If not, stay away from my thread.
Not looking for life coaching from you today.
__________________
#12 |
Drives: Marsaydees
#13 |
Drives: 2009 C 63
hi dinglberry
good to see you are being helpfull as usual have a nice day.
#14 | |
Drives: Multiple
Quote:
I intend to figure it out this weekend. I will keep you posted, A.
__________________
#15 |
Drives: Multiple
DONE. Figured it out today by mounting the lights on my truck. I figured I'll test it out on the truck and depending on how they perform/hold up, I will mount a separate set on the C55 later.
Tools needed: AZN Optics LED Strip Extra 16 gauge wire Wire butt splices Electrical tape Zip Ties Add a Fuse with two inline fuses (amps depend on which fuse you decide to tap) Mounted the strip to the bumper. I used the clamp that came with the strip and plenty of zip ties in strategic locations. Wire the ground to the battery negative terminal: Add extra wire as necessary and route into driver cabin through firewall (depending on where your switched fuse box is, you may not need to go into the cabin and might be able to do it right in the engine bay) Connect to the Add-A-Fuse and hook up to the desired switched fuse in the fuse box (my truck came with plenty of empty 15-30 amp switched fuse slots so it was easy) Neatly zip tie / tape all the wires both behind the bumper and in the engine bay: ![]() BAM. Finished product. Comes on with ignition and goes off when switched off. I will see how they hold up over the miles and how they perform in the dark as well and report back. Aussie e55, hopefully this helps you a little bit.
__________________
#16 |
Drives: 2009 C 63
hi xxaarraa
thanks do our C55"S have a canbus wiring system ? whatever that is if so would your system work. regards george
#17 |
Drives: Multiple
haha the good old canbus! I am not sure man, I have no idea. I would think canbus or not, switched power is switched power. Check it out and let us know what you find.
__________________
| Tags |
| 848, azn, aznoptic, aznoptics, car, connecting, diy, drl, ducati, evo, led, leds, optics, strip, strips, wiring |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
