RS32
Old 11-29-2012, 03:19 PM
  #76
chris.bachman's Avatar
a car.
Hot dog, hot dog, hot diggity dog...
I wanna drive it!!!
Old 11-29-2012, 04:13 PM
  #77
Sirpent's Avatar
CLK320 & C32 ******* Child
Originally Posted by paqueras
Subscribed!
This is like a "Norwegian crazy swap"!
I love it!
Hmmmmmmmmmmmmmmm
Not sure how to take the "Norwegian crazy swap", its all good as long as you love it, apart from being called a ******* Child which I actually like in some strange way, the swap isnt as crazy as the guy who came up with the idea.
Nice to have yopu on board for the ride.
Cheers
John
Old 11-29-2012, 04:17 PM
  #78
macbryanie's Avatar
Porsche 2004 911
Well done John. Awesome stuff.
Old 12-05-2012, 03:47 AM
  #79
Sirpent's Avatar
OK,
Running later than expected, but I guess the best Scotch takes time too.
Went down to see the boy's, all should be finished up tomorrow or Friday, here are some pic's of the flywheel in final stages of cnc'ing.
Also, by the weekend, John has promised he will have a complete kit price ready, what you will get is the bolt on fly wheel, dual clutch assy, bell housing, adaptor plate, and modified slave/actuator and thrust bearing assy's
Cheers
John
Old 12-09-2012, 09:14 PM
  #80
Sirpent's Avatar
Ready for collection,
Some internal pics and a layout of all the components will follow later today.
Cheers
John
Old 12-10-2012, 04:20 PM
  #81
Sirpent's Avatar
Gentlemen !
Your **** awaits !
More or less a pictorial step by step of how the conversion kit bolts together, and yes, it will be available as a kit !
Attached Thumbnails RS32-amg1.jpg   RS32-amg2.jpg   RS32-amg3.jpg   RS32-amg4.jpg   RS32-amg5.jpg
Old 12-10-2012, 04:22 PM
  #82
Sirpent's Avatar
And
Attached Thumbnails RS32-amg7.jpg   RS32-amg8.jpg   RS32-amg9.jpg   RS32-amg10.jpg   RS32-amg11.jpg
Old 12-10-2012, 04:25 PM
  #83
Sirpent's Avatar
And at last, the first ever AMG 6 speed manual conversion !!!!!!!!!!!!!!!
Attached Thumbnails RS32-amg13.jpg   RS32-amg14.jpg   RS32-amg15.jpg   RS32-amg16.jpg
Old 12-10-2012, 04:38 PM
  #84
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
there is a God
Old 12-10-2012, 06:10 PM
  #85
firstshadow's Avatar
03 C32 AMG
Looks fantastic! How much longer until the road test?
Old 12-10-2012, 06:15 PM
  #86
Sirpent's Avatar
Ahhhhhhhhhhhhhhh The golden question.
Well, chassis build first, then about $6000.00 for the MoTeC M600 or M800 brains to run it all, it will be some months at least before a running bench test can be done, as far as full blown road test, well there is the rest of the car to finish and at this stage I cant give an exact time frame.
Cheers
John
Old 12-11-2012, 03:24 PM
  #87
speed7's Avatar
07 E63 Estate | 09 & 10 Rx8 R3
What transmission did you use? I was going to use a C240 6spd however am worried that the torque of the V8 will destroy it.
Old 12-11-2012, 03:40 PM
  #88
Sirpent's Avatar
Tremac T56 6speed
Old 12-11-2012, 03:49 PM
  #89
speed7's Avatar
Ok so yeah you have 100% of my attention. What are we talking about for price? Do you have anything written up on what is needed and what the end user will need to purchase on their own?
And FREAKING AWESOME!!! I want to be the first v8 amg manual. =) I was saving my pennies for coil overs and clk63 breaks but this has always been at the top of my list. But the use of a C240 trans while would work.. I wasn't sure about the logevity of the transmission. clk6spd had to use a racing clutch just to stop the slipping on his conversion. While I'm not opposed to that I really wanted a Tremac.. like really really really wanted a Tremac.
Hey if you wanted to save some monies on the ECU conversion for a manual. Renntech will take the stock ECU, unmask it, and then program it for a manual transmission. I think their cost is around $800. That will get you up and moving for road tests I think quicker than a motech. This way you don't have to reprogram the ECU and rewire the entire engine.
EDIT:
NM on the ECU comment.. I just read through your thread and saw the note about not being able to use the ECU.
Old 12-11-2012, 03:51 PM
  #90
speed7's Avatar
Wow I'm really impressed btw.. really really impressed.. this just made my freaking day.
Old 12-11-2012, 04:11 PM
  #91
Sirpent's Avatar
OK
John at ARC who I approached, worked with, took my concept and made it a reality is finalising a price for the kit, the stumbling block is that the original Benz bell housing needs to be slightly modified as you will see in the photo's, so we have been chasing a supplier for them, sorry point is wrecking / breaking yards dont want to part them out off transmissions.
We are working on this and should have a solution soon.
This said, I dont want to rain on John's party as far as price, however apart from needing to purchase a Tremaec, set up the extra pedal in the car, have a cuctom tail shaft built and transmission crossmember, the actual conversion kit will be in the vicinity of $3500-$4000 depending on what we sort out with the bell housings.
You will recieve everything as shown in the very first photo including bell housing, twin plate street/strip clutch assy, flywheel, slave cylinder assy, adaptor plate, and full ARP bolt kit.
As far as the original ECU as oppossed to the MoTeC, cant be done in my instance.
As I dont run half the features a C32 sedan has, such as ABS etc etc etc, to use a Benz ECU without these inputs would put it into limp mode which I discuss a few pages back in this thread.
With the Motec, we are looking at tuning the engine past 300kW (400 HP) and 500Nm (370 lbf) of torque
Old 12-11-2012, 04:17 PM
  #92
speed7's Avatar
Originally Posted by Sirpent
OK
This said, I dont want to rain on John's party as far as price, however apart from needing to purchase a Tremaec, set up the extra pedal in the car, have a cuctom tail shaft built and transmission crossmember, the kit will be in the actual conversion kit will be in the vicinity of $3500-$4000 depending on what we sort out with the bell housings.
You will recieve everything as shown in the very first photo including bell housing, twin plate street/strip cluct assy, flywheel, slave cylinder assy, adaptor plate, and full ARP bolt kit.
Honestly with this type of R&D I think that's a fair price. And any M11x engine be it v6 or v8 can work with this. I'm going to start looking for my tremac now. =)
Old 12-11-2012, 05:58 PM
  #93
MBfinatic's Avatar
e36 318i, 2004 sti
LOL please do it. Would love to see that build.
Old 12-13-2012, 01:00 PM
  #94
paqueras's Avatar
G320 CDI, C32 AMG Sportcoupe, GLK300 4MATIC
Hmmmmmmmmmmmmmmm
Cheers
John
Take it in a good way my friend! Love the project!
Old 12-16-2012, 04:54 PM
  #95
Ken311's Avatar
E55 AMG, Porsche 911 SC
very cool project. I am scratching my head as to why you would just not drop a more powerful LS motor in the old Datsun shell like others have done in the past, but i like that you're taking the road less traveled. Good luck
Old 12-16-2012, 06:08 PM
  #96
Sirpent's Avatar
Think because it's been done to death, there is no doubt that an LS series engine would deliver everything I could even want as far as performance, however the challenge of of this motor and the pure fact that a manual let alone a 6 speed conversion has never been done captured my imagination.
A bit of trivia, the idea came to me when I read the history of the 240Z which used a straight six derived from the Prince motor company Datsun acquired some years earlier.
That motor is based on an original Benz 6 which the Prince motor company acquired the rights to reproduce from MB.
Guess this project goes back to some of the original roots of thinking when the 240Z was first concieved.
Cheers
John
Old 12-31-2012, 07:01 AM
  #97
Sirpent's Avatar
The old man always said each NYE
"You spend the year ahead the way you started it on NYE"
So what better way to start 2013 than to splash the cash and buy myself some more headaches.
These puppies are off a 997 GT3 Porsche, think they will eventually make their way onto the new nose, new from Porsche $3,800.00, I swipped these brand new never fitted pair for $1,000.00.
Happy new year Crew
P.S. + a side view shot of how they will sit from a web pic
Old 12-31-2012, 07:50 PM
  #98
speed7's Avatar
Happy new year Crew
I like his thinking. I plan on doing the 6spd conversion this year as my 2013 goal. So hurry it up why don't you, so we can get some proper manual AMG's rolling around. =)
Old 12-31-2012, 08:08 PM
  #99
Sirpent's Avatar
Happy new Year Buddy
John will be back in a week after some R&R, I contacted the forum moderators and asked permission if we could set him up a thread so he can elaborate on the kit and answer questions, however I havent had a response as yet.
John also seems to have found a supplier for the bell housing issue so technically the kit can be supplied imediately.
Cheers
John
Old 01-01-2013, 04:39 AM
  #100
speed7's Avatar
Cheers
John
SWEET! Don't have the cash just yet.. but I will PM you when I do. Shouldn't be too long.
Quick Reply: RS32
