Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-11-2012, 03:10 PM   #1
Drives: 2004 C32 AMG
Steering column looseness - source of strg whl play
My '04 C32 has a bit of play in the steering, not bad but annoying, did all the usual ball jt replacements, the suspension is very tight and I can grab the wheels (on a hoist) and rotate them about the vertical axis and get no slop. I had been told it was the rack by the stealership but didn't deal with it until now. Looking at the gear/column closely while having someone turn the wheel, the source turned out to be big-time (1/2") movement of the upper intermediate shaft where it goes thru the firewall. I haven't torn apart the carpet/IP lower cover yet to get at it, and there isn't anything that I could find in the STAR service CD that relates to this, just wondering if anyone here has experienced this with their C-class and whether it's A) an immediate safety hazard and B) DIY-friendly.
The dealership was perfectly happy to replace the rack at a cost of $3K, which would not have fixed the problem...*******s...
To remove this ad, register today or login if you already are registered!
jneal3110 is offline   Reply With Quote
Old 01-13-2012, 10:40 AM   #2
Drives: Cooper S, C32 AMG
Frostymugkiller
Send a message via Yahoo to Miniac
Look around you should be able to find that part separate ad save big bucks.
Haven't read anything on the C-class but the intermediate shaft are problem on a wide range of cars old and new. Ford trucks have always had problems with them. On the new Minis the joint that is in the engine bay likes to rust and causing the joint to freeze. The stealership usually says this is a bad rack and charge around 2000.00 for a 150.o part.
Miniac is offline   Reply With Quote
Old 01-13-2012, 01:08 PM   #3
SPONSOR
Drives: Mercedes
If you need the step by step OEM procedures check us out. ALLDATAdiy.com
__________________
Complete Factory Diagnostic and Repair Information!ALLDATAdiy.com provides more detailed diagrams and repair information than any paper manual. All information is specific to your vehicle.Also,Technical Service Bulletins and Recall information updated regularly!
Click: ALLDATAdiy.com
Questions? diyemail@alldata.com
ALLDATAdiy INFO is offline   Reply With Quote
Tags
column, diy, joint, mercedes, play, shaft, steering, w203, wheel
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
