Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-18-2012, 04:54 PM   #1
Drives: c32 AMG
Whine
Well after fitting an asp 178 crankshaft pulley, needswings pulley saver kit and a brand new supercharger bearing my c32 still has a relatively loud whine coming from it. Im just wondering is this normal or is there a problem with my water pump/supercharger as these are the only other things that could be causing the noise.
Ill upload a video of the noise asap.
To remove this ad, register today or login if you already are registered!
AndyStrangC32 is offline   Reply With Quote
Old 01-18-2012, 06:31 PM   #2
Drives: 2005 C55, 2007 Trailblazer SS
Do upload a video for sure. Superchargers will whine and a pulley will make it spin faster so it might be louder. I've never heard a C32, so I may not be of much help even with a video but someone should be able to.
91RS is offline   Reply With Quote
Old 01-18-2012, 06:37 PM   #3
Drives: C32 AMG
My C32 whines much louder with the Eurocharged SC pulley. So I' thinking that might be normal. Then again, you installed a crank pulley so it might be different.
__________________
AMG3.2 is offline   Reply With Quote
Old 01-18-2012, 06:49 PM   #4
Drives: 2005 Pontiac GTO 6.0 LS2 - Blue
At idle the supercharger doesn't really make much sound. Typical cause of a "whine" at idle is power steering. Check fluid level...
__________________
SOLD
2002 C32 AMG Sedan [132,000 Miles]
Clear Side Markers | CL Style Grille | Flat Emblem | CF Front Lip Spoiler | CF Rear Diffuser | CF Trunk Spoiler
K&N Air Filters | NGK IX (2 Step) | KV-85 | 185MM EUROCHARGED | TVT Thermostat | PSK Belt Wrap
Johnson CM30 | DIY Intercooler Isolation | 26x7x2 FB H/E | A/F & PSI Pillar
gt4awd is offline   Reply With Quote
Old 01-19-2012, 07:34 AM   #5
Drives: c32 AMG
I checked the power steering fluid all good but ive taken a video to see if anyone can help identify the cause of the noise
http://www.youtube.com/watch?v=D5MEmg1CeRY
Old 01-19-2012, 06:57 PM   #6
MBworld Guru
FrankW's Avatar
Drives: white and whiter
Sounds like its coming from youR s/c clutch area.
FrankW is online now   Reply With Quote
Old 01-20-2012, 04:02 AM   #7
Drives: c32 AMG
When your actually at the car though its impossible to detect exactly where the noise is coming from.
Old 01-20-2012, 08:00 AM   #8
Drives: 2003 C32
I suggest you get a stethoscope and check all the pulleys, sc clutch, idlers, ps pump, and alternator. That should pinpoint the source of the noise.
__________________
Mods: Quaife LSD, Eibach anti-roll bars, C55 dampers and front springs, LET HE, Eurocharged (Jerry) Tune, Eurocharged shorty headers, intercooler/HE separation, LET phenolic spacers, Needwings oil catch can, AEM wideband, DashDaq datalogging
03MBC32 is offline   Reply With Quote
Old 01-20-2012, 08:24 AM   #9
Drives: c32 AMG
Quote:
I repalced the supercharger bearing and fitted the need wings pulley saver kit so the only things left are the power steering and water pump and the supercharger itself id assume.
Old 01-20-2012, 12:53 PM   #10
Drives: 2003 C32
Quote:
Assuming everything was installed correctly, torque settings, bearing replacement and sc clutch gap then the ps pump, water pump, alternator and sc bearings would be the probable suspects then. Regarding the sc bearings, one forum member found he had almost no sc oil when he went to change the oil.
__________________
Old 01-22-2012, 09:36 AM   #11
Drives: c32 AMG
bump
Tags
55, amg, bearing, c32, c55, drive, idle, loud, louder, make, mercedes, mod, supercharger, whine, wine
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
