Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-16-2012, 02:58 PM   #1
mikekuriger's Avatar
Drives: c55
need help finding relay/fuse for air pump
I have a check engine light, the code is for that air pump on the front of the motor that comes on for 30 seconds when you start the car cold. the pump comes on when I wire 12v to it, so I suspect the relay or fuse is bad. I've searched all over and was unable to find the location on my C55. found it for the E55 but it's not in the same place.
I ended up guessing and found the fuel pump, horn, lights, starter, and a relay that kills the whole ECU. Also found the ABS relay. Still can't find the one for the air pump.
Please help!
thanks,
mike
To remove this ad, register today or login if you already are registered!
__________________
Mike
2005 C55 AMG tuned by OE tuning, 180,000 + miles
mikekuriger is offline   Reply With Quote
Old 02-18-2012, 09:19 PM   #2
Drives: c55
geez, nobody knows?
__________________
Mike
Old 02-18-2012, 11:53 PM   #3
Drives: 06 C55, 09 E350
front fuse box part# 002-542-26-19 look on top of the relay. The air pump always goes bad though, you may need to replace both. Let me know if you need any other help.
__________________
Resonator + Rear Cats Deleted
JonMBZ is offline   Reply With Quote
Old 02-20-2012, 03:13 PM   #4
Drives: c55
thanks I'll have a look
__________________
Mike
Old 02-20-2012, 03:29 PM   #5
Drives: c55
That's not the relay for the air pump, it's the SRS airbag relay. I'm looking for the relay on the air pump (smog pump) mounted on the front of the motor. A picture would be helpful.
thanks!
__________________
Mike
Old 02-20-2012, 10:32 PM   #6
Drives: c55
I found the problem to actually be the large 40 amp fuse. replaced it and good to go!
__________________
Mike
Old 02-21-2012, 11:41 AM   #7
Chedeng88's Avatar
Drives: C55 AMG
Nice to know you figured it out.
Can you post a pic of the fuse and its location? Thanks!
__________________
Chedeng88 is offline   Reply With Quote
Old 02-21-2012, 12:39 PM   #8
Drives: c55
Well, I thought it was fixed. I guess I'll keep testing every single relay until I find the right one. After replacing the fuxe, my CE light still came on when I did a cold start this morning. I am able to "hot wire" the pump and it comes on fine. I've already tested all the relays in the engine bay so I'll try again.
the 40 amp fuse is the only one in the engine bay fuse box. It's extra large next to a purple relay. I tested the purple relay first, and it seems it's in control of the ABS system.
__________________
Mike
Old 03-06-2012, 04:03 PM   #9
Drives: E55 AMG, Hummer H2
Have you had any luck with this?
Where's is the pump located in the engine bay btw? Can someone upload pics? TIA.
CFiftyFive is offline   Reply With Quote
Old 03-07-2012, 12:24 PM   #10
Drives: c55
The pump itself is that large black motor mounted right on the front of the engine. Once I replaced my 40A fuse, the pump started working again. No more c/e light!
__________________
Mike
Old 03-08-2012, 11:59 PM   #11
Sorry there is an error in the catalog but it has a note I didn't notice the first time. If that doesn't help let me know again and I will look into it more.
need help finding relay/fuse for air pump-untitled.jpg   need help finding relay/fuse for air pump-untitled.2.jpg
__________________
Tags
40, air, amg, amp, c32, c55, e350, fuse, location, mercedes, oe, pmp, pump, relay, rly, smog, tuning
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
