Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 03-04-2012, 12:16 PM   #1
Drives: 2002 W203 C32 AMG / 1997 Toyota Corolla AE110
Wilsophia
Aftermarket Amp wiring
Dear all,
I m from HongKong so my C32 is a RHS steer.
My c32 was equipped with a JVC HU from the ex-owner but the Bose Amp in the trunk was deleted. Those Bose door panel speakers were directly connect to the JVC but the Bose sub at the rear deck was disconnected.
I would like to wake up the Bose sub and I already got a 350W aftermarket Amp on my hand. So it need a direct power supply from the battery but I really have now idea how I can run through the firewall.
I have search some old threads that there are some hole for 4gauge size wire at the firewall which can be used but I cannot locate it in my C32. I would believe it is at the back side of the gloves box but no can search there.
Anyone here have more information about the holes ? Or any other alternative to solve ?
Wilson
To remove this ad, register today or login if you already are registered!
Wilsophia is offline   Reply With Quote
Old 03-04-2012, 01:08 PM   #2
Drives: 2005 C55, 2007 Trailblazer SS
Is the battery on the right or left side of the engine bay?
If the rest of the system is already aftermarket, I would recommend getting an aftermarket sub instead of using the Bose sub. There are shallow mount subs that would probably fit and sound better.
91RS is offline   Reply With Quote
Old 03-05-2012, 06:11 AM   #3
Wilsophia
Thanks for reply RS91,
for my RHS steer C32, the battery was places at LHS of the engine bay.
Yes, understand the Bose sub is not so powerful. But I would like to mod it step by step. Will replace an aftermarket sub later if the Bose is not good
Old 03-05-2012, 06:53 AM   #4
Then that passthough should also be on the left side. Take the hush panel from under the dash out and you should be able to see it.
Old 03-05-2012, 10:01 AM   #5
Wilsophia
Yes. 91RS,
I reach it finally when i remove the bottom panel cover under the glove box and see inside. But....
My power cord is too think and cannot go into those holes, it seems that those "hole plugs" can be removed but it is really hard to remove. I tried use pliers and screw drive to do but still stuck !
Any recommendation to proceed ?
Old 03-05-2012, 10:17 AM   #6
loudandheard's Avatar
Drives: C32/C55 AMG
Check out this thread, should help. I was able to fit two 4 gauge wires, so it's possible.
Moron's guide to aftermarket head unit installation
loudandheard is offline   Reply With Quote
Old 03-05-2012, 10:21 AM   #7
Wilsophia
Thanks for info, great to me !
But I've tried very tough but still cannot remove those plugs......I will try it again tomorrow
Thanks anyway
Old 03-05-2012, 01:46 PM   #8
michael kuzni's Avatar
Drives: 2007 E63 AMG with P2
if you can't get it, why not just drill another hole and use gromets?
__________________
2007 e63 AMG with P2 package.
eurocharged ECU flash, resonator delete, yellow TTM intake scoops, charcoal filters delete, smoked side markers, CF front lip, painted black grille, tinted windows.
http://www.youtube.com/watch?v=dhoFg...1&feature=plcp
past cars: C55 AMG http://www.youtube.com/watch?v=66Zu8-jdyUU
BMW X5 4.4i sport http://www.youtube.com/watch?v=S-zPNpRlbBU
michael kuzni is offline   Reply With Quote
Old 03-05-2012, 05:54 PM   #9
I got 4 gauge through mine using Vasoline. The plastic plugs are about an inch long if I remember correctly, so you will have to pull on them a bit to get one out. The hole is actually sized for 8 gauge, so 4 gauge isn't going to go through without some help.
Old 03-06-2012, 02:04 AM   #10
tw2
Drives: 2002 C32 AMG
I just shoved a screw driver through from inside the car and pushed the plug out into the engine bay. It was fairly easy. The hard part was getting the wire through without removing the battery.
tw2 is offline   Reply With Quote
Old 03-06-2012, 09:02 AM   #11
Wilsophia
So, the plug was pushed and dropped inside the engine bay ? Can it be found ?
So, i dun mind to remove the battery to get the wire, just worry if there is any elect. failure if the battery disconnected ?
Old 03-07-2012, 01:13 AM   #12
tw2
Quote:
Originally Posted by Wilsophia View Post
Yes. It can be found. I did not bother trying to retrieve mine. I found it difficult to remove the battery so I did all this with it in. There is no problem disconnecting the battery (negative first) and then removing it, you will find the job much easier.
Old 03-07-2012, 04:31 AM   #13
Wilsophia
Thanks, will try
Old 03-07-2012, 11:53 AM   #14
MTLdude's Avatar
Drives: 2005 CLK 55 AMG
You're supposed to have a solid 12V source in the trunck man! Remove the paneling in the trunk and you will see the wires. No need to run the wire from the front!
MTLdude is offline   Reply With Quote
Old 03-08-2012, 01:58 AM   #15
tw2
Quote:
This is true but not many people are willing to do this. Running high power accessories on OEM circuits might not necessarily lead to failures but it is risky.
Old 03-08-2012, 10:54 AM   #16
Wilsophia
Yes, as the rear Sam is costy, and I dun want to add up any high power loading to it.
Directly get the power from the battery is much safer
Old 03-08-2012, 12:47 PM   #17
MTLdude's Avatar
So you are running a 4 ga wire to wake up the 8" bose sub at the rear deck? That's overkill and that sub is crappy. I just removed mine to install two 6x9 in the rear deck and keep running my 12" sub and 340 watt amp hooked on the rear 12V source, plus my trailer lights. I think the power is sufficent enough specially if the Bose amp is out. From factory the Bose amp is sending a max of 100 watts to that sub. Looks like you're going to roast that sub in the first week!!!
Old 03-08-2012, 02:28 PM   #18
doom239's Avatar
So where is everyone getting there 12v source from in the trunk?
__________________
Cars:
2002 C32 AMG
1967 Mustang 351c
doom239 is offline   Reply With Quote
Old 03-08-2012, 04:38 PM   #19
MTLdude's Avatar
For me it's on the left side. You need to remove the paneling where the shock mount is.
Old 03-08-2012, 06:54 PM   #20
Wilsophia
No worry, if the Bose sub was killed, I will remove it and change to a 10 or 12 sub, haha
Tags
2002, 4ga, access, amg, amp, bay, benz, c32, engine, firewall, fit, hole, ib, install, mercedes, w203, wiring
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
