Sign in using an external account
| C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2002 C32 AMG
Finally ran my car at the dragstrip
#2 |
Drives: 03SL55
Nice runs. Eurocharged...good people and always good to get a custom tune.
#3 |
Drives: 2006 C55
Awesome, glad to hear the 225's worked for ya, now I'm not so worried that they won't be wide enough! Great time
__________________
2006 C55 Alabaster White/Ash/Birdseye Mods: EC Dyno Tune, Kleemann Hdrs, Dual Exh w/ X-Pipe (no cats),AMS Crank pulley, NW DCAI, PTE Cams, AMG Flat Badge, Single Fin Grille, S Class Style LED Tail Lts, Clear Side Mkrs, AZNOptics LED Side Mkr/Cty Lts, 5.5///AMG Side Badges, 19" SL65 Reps, 235/265 G-Max AS-03's, Sparco 16" Assetto Gara's w/ 225/50-16 DR's, 35% Tint, CF Diffuser & CF Carlsson-style trunk spoiler, Thermotronic retro. Soon to be installed: Wavetrac LSD, Evosprt UDPs 12.105@115.56 |
#4 |
Drives: C32/C55 AMG
Very close to what I predicted. Do you feel any difference with cams?
#5 | |
Drives: '05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Quote:
__________________
KLEEMANN< ![]() Kleemann supercharger, cams, headers & tune | H&R springs & sways | Koni suspension Brembo GT BBK, 6/4 pot, floating composite rotors | GPT pulley | Magnecor KV85 wires Carbon fiber; vented hood, Vorsteiner spoiler, diffuser, front lip and custom side vents Quaife LSD | Magnaflow quad exhaust w/ 100 cell cats | E55K airbox w/ kevlar tubes AMG Black Series strut bars | 360 Forged wheels, carbon fiber | eXce1on AV system Mods/build thread |
#6 |
My launch rpm was around 1,200 just enough to get the s/c engaged, and as far track prep I would say it was pretty good for a test an tune night, but the tires hooked so well that I don't there to finicky on the track prep. You'll defiantly be pleased with a set of drag radials it takes all the guess work out of trying to get your car to hook.
As far as the Kleemann cams I would say they made a noticeable difference in the mid to upper range power. But I've got a retune scheduled for friday with eurocharged to get my afr numbers down so I might feel a more power increase out of the cams and maybe even a better e.t. . I'll keep you'll updated. |
#7 |
I got my ecu retuned by eurocharged, and they seemed to have done an excellent job on getting my afr readings down. They seem to be great peaple to work with. So after the retune I decided to take it back to the strip. I ran it about six times an my e.t.'s ranged from 8.05 to 8.00 but my last run before leaving I managed to get a 7.99.0
. I think it was from leaving at a little higher rpm than I had been. Very pleased with the numbers considering the car has all stock exhaust system which might be the next thing, but still not sure about that yet. I,ll post a picture of my time slip.
#8 |
Drives: 2006 C55
Awesome mo! Congrats on meeting your goal
Track prep was pretty good but I gotta get me some Hoosiers soon! A 7.99 1/8th should be good for 12.3ish at the 1/4, Excellent time and thanks for sharing!
__________________
#9 |
Drives: 2002 C32 AMG, 2006 Audi A6, 2005 Subaru STi, 2013 GLK 350/4
Very good runs. I ran 8.00 flat with the 12.42 1/4 mile. Interesting to see what the cams will do for you the secod 1/8 mile. Are you runing EC TCU tune by any chance and do you have any DashDaq graphs you can share?
__________________
LET 181mm pulley, NW Pulley Saver Kit, SL55 full intake with K&N filters, Code3 HE, Code3 Reservoir (separated cooling), Meziere pump, Eurocharged Headers, Supersprint dual exhaust, Eurocharged ECU & TCU tune, Quaife LSD, Bilstein PSS9, CLK 63 front/rear brakes, Zeitronix/DashDaq data logging |
#10 | |
Quote:
Thanks, I'm curious myself on what my 1/4 mile times will be, I should be able to in the next coulpe of weeks try a 1/4 mile track in maryland at buddscreek. As fare as my Tcu tune it was done by eurocharged, I did have to send back once because I think the ECU and TCU were butting heads on shift rpms but no problems since. I just cleared all of my logs from having so many to start fresh after my retune as soon as I take it back out I'll get some more data logs to post, my afr numbers now are around 11.8 to 12.2. |
| Tags |
| 14, 181mm, 22545r17, bfg, c32, c55, class, drag, intake, led, lights, mile, mustang, needswings, pressure, radials, tail, times |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
