Sign in using an external account
| C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2002 C32
New 18'' AMG wheels purchased! Will these fit?? Help!!
#2 |
Drives: 2002 C32 AMG
They will need spacers front and back to prevent rubbing.
__________________
PLM Heat Exchanger, CM30 pump, coolant isolation install Aftermarket head unit and amp installation Spark plugs, magnecor leads, custom intake install c32 sold, now 2006 350z |
#3 |
the offset are pretty high. they will rub.
__________________
Mercedes Star DAS Star Diagnostics.. Accessible Here! C320K, C240, Lincoln Aviator |
#4 |
Drives: '03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
look at the specs of a tire and wheel package and use it as your baeline info, you're better off getting wheel and tire specific to your car. it'll save you a ton of hassle and $$$ as well in the long run. just my 2 cents
__________________
![]() AMG Northeast member AMG Orphans Club International #87 CODE 3 Supercharger Pulley SL 55 Y pipe Dual CAI Johnson cm 30 pump Iso. Kit Secondary cat delete CF Trunk Lip 19" MMR GT-1 Clear HID 4300k projector fogs. |
#5 |
They can fit. You'll need spacers I'm guessing a 15mm in the front and a 10-12 mm in the rear. Don't forget that you'll also need longer lug bolts. I'd recommend H&R spacers over Eibach spacers for the front. ( Eibach spacers come with lug nuts but will be way to long)
#6 |
Drives: '05 C55 AMG
I'd run a 20 mm front spacer, and a 15 mm rear
__________________
///AMG drive.S.low ![]() |
| Tags |
| 18, 18x95, 203, 44, amg, c55, fit, offset, rims, w124, w140, w204, w211, wheel, wheels |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
