Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > C32 AMG, C55 AMG (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-06-2012, 05:18 PM   #1
Drives: 2003 C32 AMG
Coolant Pump shaking....?
So I noticed a weird sound coming from my engine, so I popped the hood while it was running. And noticed there was a pulley that had the v belt that goes around all the other ones, and it was wobbling and shaking. It makes a pretty significant sound while driving, so I hopped on the forums and found a very helpful diagram which let me pinpoint the correct one. It seems to be the coolant pump. Now my question is, what could cause it to do this, and is it something major that needs to be looked at right away? Last night on my way home i had the coolant light come on saying to top it up, which I did.
I'm going to add the picture, but you can find it in this post and it is number 8 on the diagram.
http://m.mbworld.org/forums/showthread.php?t=290829
If someone could let me know whether or not its safe to drive it, I have to be hitting the road in an hour
And if there is a diy or quick fix to it, thats always good on the wallet :P
Thanks guys.
To remove this ad, register today or login if you already are registered!
uzi67 is offline   Reply With Quote
Old 05-06-2012, 05:51 PM   #2
320 dreamer's Avatar
Drives: 2003 porsche 996 turbo
Send a message via Yahoo to 320 dreamer
if the pulley is wobbling its best NOT to drive it. the pulley could seize come off causing way more damage then the cost of the pulley (about 40$)
320 dreamer is offline   Reply With Quote
Old 05-06-2012, 06:08 PM   #3
Forgot to add:
I had checked the 4 bolts that hold it on and they are tight. Also, I put my hand under to take a feel, and there was coolant leaked around it... Isn't looking good so far (n) I'm gonna swing it by the shop tomorrow, hopefully it is just the pulley...
Old 05-07-2012, 06:22 PM   #4
water pump :|
Old 05-07-2012, 07:57 PM   #5
Drives: 2002 C32 AMG
Send a message via MSN to Autotechnica
I just replaced mine at around 70,000 miles. The wobbling is shaft play on the water pump. There's no cheap fix, you have to replace the water pump. It's around $400-$500 for the part alone depending on where you buy it. I got a Bilstein one. I don't know how much labour would cost as I had mine replaced when I did my needswings ASP pulley kit.
__________________
BMWCC Trillium Member
2002 Mercedes C32 AMG - H&R Coilovers, H&R front and rear sway bars, H&R 10mm front spacer, Quaife ATB LSD, EBC redstuff brake pads, Goodridge SS lines, NW CAI, Greddy catch can, custom water/meth injection kit, Johnson CM30 pump, Eurocharged remap, Magnecore wires, NGK laser iridium plugs, NW ASP 178mm Pulley, NW PSK, NW Iso, AEM UEGO wideband AFR, 18" CLK55 wheels, CF front lip, rear spoiler, rear diffuser, custom quad exhaust (cat/res delete)
Autotechnica is offline   Reply With Quote
Old 05-12-2012, 10:41 AM   #6
$780 parts + labour but she's running again
Old 05-12-2012, 01:18 PM   #7
Zeppelin's Avatar
Drives: C32
My local auto parts store has new water pumps for $86. Granted not a mercedes OEM part but good enough for me.
Zeppelin is offline   Reply With Quote
Old 05-12-2012, 08:56 PM   #8
I wish your local parts store was in toronto all the shops here had no stock of water pumps or they were only about $30 less then MB. oh well you win some you lose some
Tags
203, amg, benz, c32, coolant, engine, enging, mercedes, noise, noisy, powered, pump, shakin, shaking, slk32, vbulletin, water
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
