Sign in using an external account
| C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: C32 AMG Ram 1500 4x4 GSXR600R Track Bike
Funny problem with c32. Help?
__________________
It's only $110,000. You know you like to press a lot of buttons when you drive around. Last edited by mikev7; 05-24-2012 at 10:27 PM. |
#2 |
Drives: 2002 C32
Look up CPS, Crank Position sensor.
Sounds like this is what it is, not positive, but symptoms sound like it. Tends to fail when the sensor gets old and when the engine gets hot, it causes it to fail. Then, once it cools off, car starts again. Not that your engine is over heating, but being hot for a long period of time. If it happens again, pop the hood, let it cool off and magically, in 15-20 minutes it will start again. Luckily they aren't that that expensive.
__________________
![]() Always, --Gramma_Benz--MY Eurocharged BEAST EUROCHARGED 185mm Crank Pulley, EUROCHARGED Shorty Headers, EUROCHARGED Heat Exchanger & Custom 185 Eurocharged "Jerry" Tune, SL55 Full Intake, Carbon Fiber front lip, K&N's, IK20's, Sprintbooster, Resonator Delete, Johnson CM30, Tein Basic Coilovers, NeedsWings Pulley Saver Kit Latest Jerry Tune= 372RWHP 360RWTQ Me on YOUTUBE: Finishing off tires |
#3 | |
Quote:
__________________
It's only $110,000. You know you like to press a lot of buttons when you drive around. |
#4 |
Drives: Shelby GT500
CPS
__________________
Sold as it is... 150Amp Bosch Alternator, Battery moved to the trunk, Sprintbooster, 178 pulley kit, short headers, all 4 cat's delete, K&N filters, NGK IX Iridium s-plugs, 100% aluminium Intercooler outer unit, Garret intercooler with thermal coating from needswings, cm30 Johnson pump ECU tune Stage 2, 18" MRR GT-1 wheel, Carbon fiber hood with vent holes. H&R Springs. |
#5 |
Drives: C32
If you had the ECU out for the tune you might just double check the connectors are on all the way.
#6 | |
Drives: '03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
Quote:
__________________
![]() AMG Northeast member AMG Orphans Club International #87 CODE 3 Supercharger Pulley SL 55 Y pipe Dual CAI Johnson cm 30 pump Iso. Kit Secondary cat delete CF Trunk Lip 19" MMR GT-1 Clear HID 4300k projector fogs. |
#7 |
actually i have big arms. im a contractor and all i do all day is lift heavy things. im used to losing a little skin while trying to fit my arms into tight spots though. i can manage somehow. I ordered the part last night. I tried the ecu zep. It was fine.
Thanks y'all.
__________________
#8 |
You might want to go nearest mec. shop. It is really tight place. CPS in my car stuck for good, so I used opportunity when I removed the supercharger for oil change and pulled it out.
__________________
#9 |
why did you remove the whole thing?
__________________
#10 | |
Drives: C32
Quote:
#11 |
To make sure there's no oil left in the unit.
__________________
#12 |
__________________
| Tags |
| 2002, amg, c32, crank, problems, sensor, stuck |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
